6637 install trouble
Old Oct 23, 2007 | 12:10 PM
Izzy351's Avatar
Izzy351
Here's mine, CCV mod, bottom tray, and all...
Old Oct 23, 2007 | 05:55 PM
nhill2090's Avatar
nhill2090
i need to get around to ordering a 6637 filter and ditching my k&n
Old Oct 23, 2007 | 07:00 PM
squaredancer's Avatar
squaredancer
Same here ! My credit cards twitch everytime I log on to this site !
Old Oct 23, 2007 | 09:16 PM
guitarpicr's Avatar
guitarpicr
You got that right Squaredancer . Its worse ( or better) ? than going to Home Depot and trying to walk out without buying any new tools LOL
Old Oct 23, 2007 | 10:20 PM
Capt.Schenk's Avatar
Capt.Schenk
I just found my new 6637 on the front porch. I yanked out the K&N and had the 6637 installed within a few minutes. No clearance problems. I took a wet paper towel to wipe-out the tube to the filter thinking the K&N wasn't filtering properly, and there was nothing. Clean as new.
Old Oct 23, 2007 | 10:38 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Uhmm, this Kwikk or 6637 mod is among the simplest you can do. If you cannot overcome or do this one, you may need to keep it simple. It fits in there just fine.
Old Nov 10, 2007 | 08:41 AM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
Could you please tell me what the CCV mod is? Thanks.
Old Nov 10, 2007 | 08:49 AM
TurtleRacing
PSD Addict
Sorrry, I see now.
I just got my 2002 and I will be doing the 6637 as soon as I can get it and some 4" tubing.
Old Nov 10, 2007 | 08:51 AM
F250_'s Avatar
F250_
I know that you said that you see what it is now, but here is an excellent link for additional reading.
https://www.ford-trucks.com/forums/284862-ccv-mod.html
On the 6637 mod, some folks have used a piece of 3" PVC coupling, but you end up reducing the inside diameter slightly on the intake side of the turbo, which will serve as a flow restrictor to some degree. Worst case is that you can take that approach and improve things in a non-ideal fashion if you absolutely cannot find the 4" exhaust pipe (which can be ordered from some online exhaust shops).
Old Nov 11, 2007 | 10:22 AM
mikeb2's Avatar
mikeb2
I did the 6637 mod and I had to loosen the hose clamp on the intake hose and rotate the filter slightly so it would fit under the hood. That is probably obvious but I thought I would mention it. I also left the bottom of the air box in place.
Old Nov 11, 2007 | 11:31 AM
TurtleRacing
PSD Addict
Thanks F 250, that explains it much better, I will be doing that and the 6637 this week.
TEA4TX
Oct 20, 2013 11:16 AM
Blue 55
Electrical Systems/Wiring
Dec 26, 2010 12:40 PM
steve442
Sep 9, 2008 02:35 PM
Ed2
All Things Towing
Mar 17, 2004 12:20 PM
