Explorer Total Power Fail
Old Oct 19, 2013 | 12:05 PM
TEA4TX's Avatar
TEA4TX
2005 Explorer 4.0 2WD Eddie Bauer: Got Charging system check message. Both Alt & Batt checked out bad. Bought Both. Installed Batt only. Started right up. On way home to install Alt, made one stop - would not restart. No dash lights even. What are the possiblilities. Main ignition fuse under hood in fuse/ junction box? A relay?, Ignition switch? If fuse, is it under where red batt cable to box attaches? Or where? It is listed as #58 but not visible from above. Don't have test light - about to get one.
Old Oct 20, 2013 | 11:16 AM
shorod's Avatar
shorod
Did you check the battery cables to make sure they are still installed and secure? Maybe you forgot to tighten one down and it fell off the battery....
-Rod
joeimp
Electrical Systems/Wiring
Jan 15, 2018 07:33 AM
Eaglescout94
Jan 8, 2016 01:09 PM
Archuriel
Oct 1, 2013 01:02 AM
zzrich
Mar 8, 2008 11:06 AM
macjb
Sep 11, 2006 06:34 AM
