Good pics and talk guys!! Too bad I didn't check this earlier today. I could have taken and posted pics of my HPOP that I have began to tear apart. I bought it ($25) just to rip open for my future DIY big oil project!!
Jim just a tip if you start to tear your apart. The front seal needs to come out first. Remove the snap ring and press the shaft and front bearing out the front. I am working with a 15* so thats are far as I have gotten so far as I need to remove the rear bearing as well. Not much time at the shop other than when I am punched in on thursdays.
Tim, no way...I get the stupid award. I have no idea what these mean.
LLIB
kcir
sggeb Jt
Thanks fro the tip on the seal.
Did you read the part about identifing 17* pumps from the outside. I was disappointed when I discovered they may have a bushing instead of a bearing. I guess it depends on the core they use for remans.
Yes I knew about the back cover not being the tell all. The 17* use the bushing and the 15* use the bearing. i have pulled the cover off 3 pumps. 2 15* and 1 17*.
Jim here is the secret decoder key
LLIB-Bill (madvan) backwards
kciR- Rick (action4478)
sggebtj-Me
