Yep!
That's the back side of the screen. That was installed at the time of the new IPR. The old style IPR had what was called edge filter on the end of the IPR.
Yep!
They still call it the edge filter after the move into the pump.
...RICK...
Kansas has not had the time to figure his issue out yet (no time).
Possible his problem might be electric also. (loss of IPR voltage after ign sw goes from start to run). Hands on is easyier than Keyboard troubleshoot on this one.
...RICK...
Bill
His original problem was High ICP & low IPR dc% (8%) path to the drain.. Different problem now....
The bolt is like you would see in a rear diff to remove the pin.
I have never tried to remove a screen. I have been told you cannot.
If it can be remove from that side of the pump. I believe that you can clean/service it. Just have been told you cannot.
