Alternator light and more
Old Sep 9, 2007 | 07:06 AM
msoller68's Avatar
msoller68
Exclamation Alternator light and more
I have an alternator light that stays on. What could be the problem?
How do you fix a fuel guage thats incorrect; he guage or sender unit needs to be replaced?
Oil pressure guage not working...could it be the sending unit?
Thanks for all your input.
Old Sep 9, 2007 | 07:32 AM
66F100Again's Avatar
66F100Again
If your gauges all starting failing at the same time, you might check the "constant voltage" regulator mounted on the back of your gauge cluster (speedometer housing). It creates a reference voltage for your guages. Also, check your chassis ground wire(s).
The gas gauges aren't super accurate; it could be that the brass float from the sending unit has a pinhole; remove it from the tank and if it feels heavy and/or sloshes inside when you shake it, a new one is around $5 from any of the sponsors or other suppliers. The gauge itself is usually not the problem.
Oil pressure might be a loose wire...or as you've mentioned, the sending unit.
Start with the cheap solutions first.
choptop49ford
21
Nov 22, 2012 08:24 AM
fivepointohno
Oct 12, 2012 03:24 PM
derek0525
13
Jan 2, 2012 04:51 PM
kamloops
1997 - 2003 F150
Apr 26, 2008 11:35 AM
TBloggins
Mar 12, 2006 10:36 PM
