No guages except spedometer?
Old Oct 8, 2012 | 10:47 AM
fivepointohno's Avatar
fivepointohno
As the title says I have no guages except the spedometer and odometer. All light work but no guages any idea what could be the issue?
Old Oct 8, 2012 | 11:12 PM
fivepointohno
I read that there is a silver box on the back of the instument cluster that could of gone bad that is the voltage regulator but i do not see it on my guage cluster,
Old Oct 9, 2012 | 09:08 AM
dixie460's Avatar
dixie460
What have you checked so far? Fuses? Grounds? Anything else not working? What were you doing when it happened?
Old Oct 9, 2012 | 10:23 PM
fivepointohno
i have checked all the fuses and I mis-spoke before fuel guage also works. I was wiring the truck for an alarm the only wires I have taped into though are a black/ w green stripe and a red/ w blue stripe for remote start. U gave checked grounds I am asuming the two under each kick panel, plus chassie cab and motor.
Old Oct 10, 2012 | 12:34 PM
RIKIL's Avatar
RIKIL
there are three connectors on the back of the PSOM and if you have lights then you are getting some power through at least some of those wires. I would find it hard to believe that any of those connectors has gone loose, they are in there really tight. This issue, without more info, looks to be a not-very-common issue.
Maybe this context will help: https://www.ford-trucks.com/forums/1...m-95-f150.html
Old Oct 12, 2012 | 03:24 PM
fivepointohno
alright so it was a fuse after all..... the wire had worn away the plasic protection on the back of the fuse [anel so when I replaced because I blew it I thought that i was good well it was still touching I did not know any of this because I thought I origanally blew the fuse while testing circuts for the alarm. Went back and douple check everything and fuse was blown again so I started looking at wies and found the rubbed through one we are now fixed and runningn like a champ again.
rockcrawler_101
Jul 4, 2011 10:31 PM
4x4jedi
May 28, 2011 10:50 AM
ford4life69
Jan 29, 2003 09:16 PM
AaronW
Oct 24, 2001 12:57 AM
Supercab
Feb 28, 2000 08:07 PM
