Battery Drain Problem
Old Jan 1, 2012 | 10:46 AM
derek0525's Avatar
derek0525
It's Sunday so nothin is open but my truck for the last few days when I go to start it when I turn the Key on the battery light is on and the guage is sitting right on the bottom line of the guage it starts but starts like it would with a week battery ( get the wrrr sound) once it starts up within a few seconds the guage climbs up to where it's supposed to be. So could it be a battery goin bad not thinkin it's the alternator cause it seems to be charging it. Thought maybe voltage regulator but thought that wouldn't let the alternator charge the battery. Any ideas?
Old Jan 1, 2012 | 11:59 AM
Superduty ROCKS's Avatar
Superduty ROCKS
Mine did this, and was the gpr stuck on. Not sayin thats what's wrong with yours, just a component to rule out.
Tom
Old Jan 1, 2012 | 12:18 PM
derek0525's Avatar
derek0525
So how you go about checking that? I have a Auto Enginuity not sure if I can check it with that or not.
Old Jan 1, 2012 | 12:42 PM
PaysonPSD's Avatar
PaysonPSD
Use a VOM to check output of GPR. Post 2 should always be hot.
Post 4 should only be hot when GPR is operated or stuck operated.
Old Jan 1, 2012 | 06:03 PM
derek0525's Avatar
derek0525
Alright thanks I will go check that out.
Old Jan 1, 2012 | 06:07 PM
carltonwebb's Avatar
carltonwebb
I think it is probably a bad battery or connection to it. It seems to me that the GPR would totally drain batteries fairly quickly if it was stuck.
Old Jan 1, 2012 | 07:57 PM
derek0525's Avatar
derek0525
Well checked the relay and Post 2 had 11. Something volts post 4 was zero post 5was like .54 post 3 was .3 something. I will drive into town tomorrow and have them check batteries I guess.
Old Jan 1, 2012 | 08:11 PM
PwerStroke99's Avatar
PwerStroke99
My guess would be a weak battery. Replace both, don't just replace one
Old Jan 1, 2012 | 08:22 PM
derek0525's Avatar
derek0525
Ya I always replace both now the ones I have nOw are red top optimas probably won't go that route again they are probably 6-7 years old so it may be the culprit I will post up my findings tomorrow. There is a shop in town that deals with just mainly electrical problems they roll out there fancy Snap-on machine. Hopefully they can figure it out just thought I would try to trouble shoot it on my own first. I hate dealing with electrical crap.
Old Jan 1, 2012 | 11:17 PM
Pitcrw6's Avatar
Pitcrw6
I have the same problem with both my 350 & Ex if I dont drive it for a week. Both batts have been changed at same time. I never ck'd the GPR but now I know how to ck it. Right now my truck is sitting with a Battery Tender on it till I get home.
Old Jan 2, 2012 | 12:31 AM
PwerStroke99
thats a good amount of years for those optimas. I will never run them again, mine(yellow tops) didnt last half that long
Old Jan 2, 2012 | 06:58 AM
derek0525's Avatar
derek0525
Well they never punched a date on the batteries when I got them so I wonder what the warrenty is on optimas. If I do have to buy new ones I will probably go with the diehard dry cell or just get some Les Schwab specials. I know the factory motorcraft are good but the stealership here will rape you on anything you buy.
Old Jan 2, 2012 | 04:31 PM
derek0525's Avatar
derek0525
Said both batteries are toast so will get some new ones and see.
Old Jan 2, 2012 | 04:51 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I'm luck y to get 3 years on batteries haha. My f250 is a little easier on them than my Excursion though... I usually get a warranty done on those before three years no matter what batteries I use.
Timbid
May 26, 2018 09:31 PM
2fifty
Apr 15, 2018 01:50 PM
sandrew1202
25
Feb 16, 2018 12:51 PM
DiGangi
1983 - 2012 Ranger & B-Series
Sep 21, 2005 02:33 PM
Duran7
Electrical Systems/Wiring
May 20, 2003 01:46 AM
