Intermittent Alternator (battery) Light
Old Mar 11, 2006 | 10:16 PM
TBloggins's Avatar
TBloggins
It started acting up the other day. If I jump on the accelerator or kick it into pass on the highway, my alternator light comes on. The volts drop off on the guage, and the altenator is showing no output. All of a sudden, it will go out and the guage comes up to about 17 volts, with nothing running. I've checked the wiring at the alternator, and it seems tight and connected. The belt has sufficient tension. Has anyone come across this before, and what was your fix? I can get a new 75 amp unit, if this one is goiing south. Or maybe it's a wonky voltage regulator? I don't want to get a new alt if that's not the problem. Thanks.
Old Mar 11, 2006 | 10:38 PM
quicklook2's Avatar
quicklook2
the voltage regulator is part of the alternator.
sounds like you need to replace or rebuild it.
Old Mar 12, 2006 | 08:13 AM
subford's Avatar
subford
The brushes are about gone, you can replace them or the alternator.
Old Mar 12, 2006 | 03:18 PM
TBloggins's Avatar
TBloggins
Thanks guys. Swapped it out in about ten minutes. Works fine now.
Old Mar 12, 2006 | 10:36 PM
Boss429F150's Avatar
Boss429F150
check all of your wiring in the charging circuit. I had the same problem in my '89 F150 and thought altenator until it happened again. Turned out I had a fusible link that was corroded and a couple broken wires. My main problem was the wire for the battery light and voltage gage.
weems67
Jan 4, 2023 03:09 PM
Texas Bob
Dec 6, 2015 09:44 PM
eman588G
Jun 11, 2015 02:06 PM
swampdonkeyvt
Apr 2, 2014 12:57 PM
greg_8507
Jan 20, 2014 03:43 PM
