$$500$$ Reward!!!!
Old Sep 7, 2007 | 08:40 AM
  #76
jas88's Avatar
jas88
I am guessing the pressure on the cam would slow it down tho.
Old Sep 8, 2007 | 07:16 PM
  #77
reneodell's Avatar
reneodell
i have learned that the hardest thing to figure out is the easiest to fix
but the pressure could be cutting off the supply
Old Sep 8, 2007 | 07:25 PM
  #78
Critter183's Avatar
Critter183
I bet you have a head gasket leaking water into a cylinder, creating a hydraulic lock up condition.
Old Sep 8, 2007 | 08:54 PM
  #79
LoosMaster's Avatar
LoosMaster
I doubt it. When I pull the plugs and spin it over nothing comes out. The plugs would show water on them. The trucks sit for a month or more before I get to work on it and the walls show no signs of rust.
Old Sep 9, 2007 | 06:09 AM
  #80
fonefiddy's Avatar
fonefiddy
It sounds to me like it's a timing issue.
The ECU tells the truck to advance timing to start, then, after it see's a start condition, it's dropping the timing off the chart?
Have you double checked the valve train geomentry? Set the #1 to TDC on compression stroke , then remove the valve covers. Make sure the Distributor is pointing @ #1, then rotate by hand????
Old Sep 9, 2007 | 06:23 AM
  #81
JLDickmon's Avatar
JLDickmon
Originally Posted by LoosMaster
It is SD. That is the 3rd camshaft I tried. 1st was the original, then a high-torque performance, which I found out later was not computer compatible, then the CompCam one. All had the same symptom. Also has new lifters that came with the latest cam. I don't have any pressure release when I remove the plugs but it does take about 4-5 full spins on the engine to get it to spin over easy with the plugs out.
After the "No Start" the cranking speed slows down dramatically. After the 3rd attempt, the starter can no longer turn over the engine and I have to remove the plugs.
P.S- The compression is about 70-80psi. No break-in time.
you just answered your own question.
with that low of compression, you also have no cranking vacuum.
and I'm willing to bet you $500. reward money you have a restriction in the oiling system of the camshaft (like a cam bearing covering the oil port in the journal)
that cranking rpm slowing down is mechanical, not electrical
now, quit screwing around with the electronics and get the engine out of that damn truck.
oh yeah, btw, I drink this:
Old Sep 9, 2007 | 08:40 AM
  #82
oldproudvet's Avatar
oldproudvet
Sometimes it is the weird crap............. A few years ago, I had somewhat the same issues with my '88, everything changed/swapped or new, no help. What I finally found, after letting the lump sit for 6 months was interesting. The female plug, that plugs into the eccIV power relay had the red power wire corroded away to just one strand. You have to take the plug apart, the wires out of to find this sort of thing. The other wires were fine! What would screw you up is the one strand would pass voltage, indicating correct power, but could not pass high enough current to keep the truck running. The other wires were not corroded and the truck is not rusty, so it had to be a chemical/flux reaction at assembly I guess. Shortened the wire an inch, resoldered the crimp and away I went. You're probably going to end up finding something like this, you've covered all the "parts"
Old Sep 12, 2007 | 06:28 AM
  #83
302RP's Avatar
302RP
Did you ever get this running right and what was the problem?
Old Sep 12, 2007 | 07:44 AM
  #84
oldproudvet
The problem was the corroded wire feeding the computer, one strand would not pass enough amperage to run the "box". It would, however, give you enough voltage to indicate that the connection was ok, it would indicate 12 volts with the power on. A digital meter would register 12 volts, an analog meter would not indicate voltage. That's how the problem was located. The truck runs great. 460 5 spd with well over 250,000 miles. One timing chain @ 175000. A good complete header exhaust (Banks engineering), synthetic oils, good state of tune etc gives me 14/15 mpg and pulling a loaded goose trailer (15,000#) I get in the 10 to 12 range running 70. 4.10 gears. Other then continuous fuel pump/tank/overflowing issues over the years I'm happy.
Old Sep 12, 2007 | 12:21 PM
  #85
302RP's Avatar
302RP
Hey thanks for the info but I was asking LoosMaster if he got his problem solved and what was the fix.
Old Sep 12, 2007 | 01:21 PM
  #86
reneodell's Avatar
reneodell
my husband syas you need to replace a chip.
Old Sep 12, 2007 | 04:13 PM
  #87
albung's Avatar
albung
chip only helps when the truck runs
Old Sep 12, 2007 | 07:05 PM
  #88
chrono4's Avatar
chrono4
truck only runs if "chip" aka coputer works.
Old Sep 12, 2007 | 07:55 PM
  #89
netscaner's Avatar
netscaner
Actually, if you had a bad chip or ECU, or bad distributor module ect, although very rare, it could possibly be a start, run for a few seconds than quit for quite a while thing.
Old Sep 13, 2007 | 02:22 PM
  #90
eco's Avatar
eco
Since you have such low compression to begin with, not to mention a problem with your set up be it incompatability of parts or the motor is not set up properly or whatever, it seems that it would be best just to start over from scratch. Say you do figure the problem out...then you have a gutless wonder due to the low compression...so either way you loose. I say yank everything out from under the hood, get a 351 crate motor/C6/8.8 and set it up for a carb....either that or mass airflow.
