highest mileage on 4.2 ??
I'm having a recurring misfire with cylinder # 3. Have to clean the spark plug every two to three thousand miles or it will start lugging while cruising with light acceraltion around 45 miles per hour. Doesn't look like oil fouling to me -more whitish. Took it to a shop because it was hard to turn over once or twice in the winter so I was worried that it may be going hydrolock on me since sometimes I can smell antifreeze, and they said there was no issue with that and that is just an old engine. ????? Well, at a later date the idiots at this shop screwed up my isuzu in a bunch of different ways, so I don't think they know what they're talking about half the time.
At random times I could get a slight wiff of antifreeze in the winter time and there would be residue on top of the oil filter cap also. Sometime last winter I put some coolant system stop leak in it, so I will see if that has any effect on anything.
I'm the second owner of this truck. The first owner had it for 19 years and according to the carfax report,he dealt with the dealership for maintenance and the one recall it had for a fuel line.
That's the WRONG thing to do. It could be the next time you go to start your vehicle, it could be next week, next month......you never know. But, if you continue to roll the dice without getting the engine checked out to see where the antifreeze is leaking from, you're closer to having that new 5K lb. lawn ornament!
Here's some reading you better do to see what you're in store for if you don't have the engine checked;
https://www.google.com/search?newwin...w=1094&bih=511
Luckily I have an Isuzu that's my main driver and a backup Ford Explorer. I will be taking the truck 2 to my new repair shop and will probably get a totally different answer than I did from the idiots across the street that I had been going to.
I too owned a 97 F150 with the 4.2 V6. I didn't want to believe the stories everyone was telling me.......at first! Then, my engine started losing coolant. You better believe me, I had that truck to my Ford dealership to have the lower intake gaskets replaced. But, instead of installing the NEW UPDATED gaskets, they installed the SAME type that were failing! They had to do the job again, and ALL was well.
Jay, please believe me, this is NO matter to just WATCH! If your engine fails due to hydra lock, and you knew you were warned ahead of time, just think how bad, mad, sad, you will feel and/or be, knowing you could have fixed it! Also, make sure you have your VIN checked to see if the timing cover gasket was replaced during the RECALL!
https://www.carcomplaints.com/Ford/F...g_system.shtml
Jay, the proof is there in EVERY fact filled story in the GOOGLE SEARCH I posted.
Like I mentioned, I took it to shop across the street last winter and told them I was worried about possible hydrolock situation, and they said they did a bunch of tests and that everything was okay, but as it later turn out they misdiagnosed a bunch of **** and did really crappy job on my Isuzu so I don't trust anything they say anymore. I can misdiagnose and just keep replacing Parts until I get it right, myself without paying top dollar for parts and labor!!! I don't see how dirt bags like that stay in business. I'm on unemployment right now and just finished CDL school so I'm done with expensive projects for the time being. Good thing I have other vehicles to drive...
Jay, you can do this job yourself. The ONLY reason I had FORD do it is because I was making good money ($70K a year) at the time. I'm currently disabled and am on SSDI. I have helped a couple of my friends do both jobs on their 4.2 engines. You really don't need any special tools. What you don't own you can rent from an auto parts store. I would ONLY use FORD revised/updated gaskets! You own other road worthy vehicles, so you just take your time on the repairs. That way it's done correct without rushing it.
Go to this forum and look it up there. Member FAIRLANER did a great in detail job on this project.
https://www.f150online.com/forums/se...=8951048&pp=25
Thanks. I have been reading and watching videos on this for the last few hours. Started looking into this last winter. normally I used the F-150 for work in the winter time because I would do long shifts and there was plenty of room to sleep on that big front seat.
Unfortunately, I don't have a garage or carport and live in a RV park where they don't allow any projects like this.
Good luck and keep us posted!
After reading and responding to the post on "what's the deal with the 4.2?" I was wondering...are there any (especially 2000 and newer) high mileage 4.2L motors out there. I'm talking factory motors that have never been in to. AT 53,000 mine (2000)is fine, but I figure there have got to be trucks out there with higher mileage. Feedback ???
Thanks,
Brian
Thanks,
Brian
Hello fellow members. Here's the latest on my 2007 F150, 4.2 V6
It's almost at 149K miles. The cam synchronizer is being replaced this weekend. Mine started whining like a school yard of screaming children.
When it does that it means the bushings need to be oiled (which can be done, if not too far gone), or you can replace it. I recommend the SPECTRA PREMIUM part # FD-34. It includes the timing tool, sensor, and has a lifetime warranty (and, it's made in AMERICA!).
Another item that's wrong with my truck is, the brake light on the dash cluster lights up on/off intermittently. To fix that I have to remove the cluster/dash pieces. There is a huge wiring harness that is plugged into the cluster. The wires are bent at such a bad angle that it causes the light to come on/off. On a YOU TUBE video a tech recommends wedging something under the wire to ease the tension.
Other than those 2 items, my truck runs/drives great! I have been using CASTROL (Made In Germany) 0W40 oil and a M1-209A oil filter. My engine is as quiet as a church mouse (when the synchronizer is not whining) using this oil/filter combo.
I'm enclosing a video (Mustang with the 3.8, which is basically a 4.2) of a Mustang's cam synchronizer whining, and a video of a FORD TECH oiling the bushings on a CS similar to the 4.2.
2004 – 2008 FORD F150 LCD ODOMETER AND BRAKE LIGHT REPAIR
115 Reviews
$149.99
https://circuitboardmedics.com/2004-...-light-repair/
115 Reviews
$149.99
115 Reviews
$149.99
