Engine pulling tips
Old Aug 24, 2007 | 08:05 PM
  #31
4tl8ford's Avatar
4tl8ford
Rustfarmer
Drain and pull the Rad.
The Rad mount (big heavy u shaped piece) holds all the sheet metal together.
You might be able to sit the doghouse in the bed. I've got a panel so I don't know for sure.
Old Aug 24, 2007 | 08:17 PM
  #32
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by 4tl8ford
Rustfarmer
I think it would have to be stood on end (cowl side down) and you risk a few scratches/dents unless you've got lots of blankets. (I assume you are thinking of putting it in this truck's bed, not some other). I carried a '51 front clip home in a LWB '78 Ford F-150, it fit but the wheelwheels of the '78 prevented it sitting down flat.
Old Aug 24, 2007 | 08:49 PM
  #33
4tl8ford's Avatar
4tl8ford
I was thinking on end, nose down, in the back of the Truck what owns it.
I keep forgetting there may be Dressup Trucks out there.
I rolled mine forward so it was sitting on the bumper, lifted (dropped) it to a milk crate, then onto my toes. I then placed it on a two wheel dolly and moved it into the garage where it sat (on it's nose) for a year before I dissmantled it.
Treat 'em as a Show Pony and thats how they'll act. (L)
Old Aug 24, 2007 | 10:17 PM
  #34
rustfarmer's Avatar
rustfarmer
I'm hoping to put in the bed of the 54. Hopefully it will fit. I guess theres no way of knowing until we try it.
Old Aug 27, 2007 | 12:31 AM
  #35
t900enforcer's Avatar
t900enforcer
Using the four mainifold bolts for the pull should work just fine. There was a fairly extensive article in HotRod or Mustangs & Fords about a year ago. They tested the holding strength of the four maifold bolts and found that they are more than sufficient for an engine pull.
Old Aug 27, 2007 | 07:44 AM
  #36
ALBUQ F-1's Avatar
ALBUQ F-1
I think you are talking about the four carb mounting bolts, usually 5/16" bolts, used on OHV engines. That is fine for a 302, 351, etc. On a flathead Ford engine, there are only 3 carb bolts and the engine weighs quite a bit more than a 302/351/etc. It is much safer to lift with four of the intake manifold bolts (that hold the manifold to the block) after removing the manifold.
Old Aug 27, 2007 | 08:21 AM
  #37
john fin's Avatar
john fin
Pulled it
Check out my pics of the engine&trans pull this weekend. 10 minutes over the fenders and without use of tilter.
Old Aug 27, 2007 | 11:26 AM
  #38
rustfarmer's Avatar
rustfarmer
Guys thanks for the info on this thread. I pulled the front sheetmetal on the 54 this Sat. I'm glad I did. It was really easy. It sure will make replacing my motor mounts easier. I have a Camaro subframe with a late model 5.0. One of the homemade motormounts is cracked so I have to redo it. While I am at it I'm going to move my motor forward towards the radiator. The Previous owner set the motor so far back that the firewall had to be recessed about 6 inches. I'll have to fix the firewall too. Having the sheetmetal off makes total sense with what I have to tackle.......Thanks again!..........
Old Aug 27, 2007 | 11:53 AM
  #39
black58's Avatar
black58
Is that a dead mouse in your oil pan? Wild!
Old Aug 27, 2007 | 02:52 PM
  #40
john fin's Avatar
john fin
Yep
Yes, that is a dead mouse in the oil pan. When I bought the truck, the fuel pump was missing. I assume he got in there, lost his footing in the valley area and fell into the oil pan and drowned.
Old Aug 28, 2007 | 06:59 AM
  #41
GreatNorthWoods's Avatar
GreatNorthWoods
I'm glad I'm not the only one with mice in my engine...
Old Aug 28, 2007 | 07:58 AM
  #42
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Vern,
Last night I read this post and I was going to make some form of smart-alek remark, but in the end I figured I have razzed you enough over it and decided to let sleeping dogs (mice???) lie. ( I better go see a doctor...............I can't believe I passed up an opportunity like that..............)
Bobby
Old Aug 28, 2007 | 11:25 AM
  #43
4tl8ford's Avatar
4tl8ford
Bobbie
But Vern does have a Rat/Mouse Motor doesn't he?
Old Aug 29, 2007 | 08:50 AM
  #44
GreatNorthWoods
Originally Posted by bobbytnm
Vern,
Bobby
Bobby,
While I appreciate the thought, I know it took everything you had to hold back and it's not good to hold things in like that. It's history now...so razz away!
And Dick, I did have mice in my motor and it's a mouse motor to boot!...
xavier9480
Sep 3, 2015 07:53 PM
shuey24
Sep 21, 2014 08:32 AM
Ole Gray
Exhaust Systems
Jun 8, 2006 09:22 AM
Guffen
27
Mar 17, 2006 12:26 AM
ucmeflyby
Jun 2, 2004 01:20 PM
