T19 Shift Fork Problem/Question
Old Sep 2, 2015 | 11:53 AM
xavier9480's Avatar
xavier9480
So I finally got my f350 truck running well engine/fuel wise, and had been driving it around my parking lot with no issues.
Took it for a test drive, and less than a mile out started hearing a noise in the trans like a marble was bouncing around in there.
Eventually and still less than a mile, truck would not move forward in first gear, and then it started moving in reverse in first gear. Could not get it out of gear either, so had to drop the driveshaft and pull it home.
I pulled off the top of my T19 trans expecting to find something obvious, but everything looks fine. Gears aren't grinded up, and neither are shift forks (plastic tips on the bottom are still in tact).
Just wondering if anyone has any insights. I don't have the top all the way out as I don't have enough room to slide it out as it sits. Next step I guess would be to drop the trans. Again, any insights would be greatly appreciated.
Old Sep 3, 2015 | 07:53 PM
Franklin2's Avatar
Franklin2
I would start looking for a new tranny. Unless you have been in one before, I would not mess with it.
I am assuming you have a 4x4 with a 460. Here's some hits in PA, $250 sounds pretty reasonable.
1987
Transmission
Ford Truck F350 7.5,MT,2DR,4X4 J13144 $250 Drive Line Auto Parts USA-PA(Philadelphia) Request_Quote 1-888-213-3522 Request_Insurance_Quote
1987
Transmission
Ford Truck F250 7.5 4SP 4X4,STOCK NO. #JD219164 #JD219164 $Call Ambrosius Auto Parts USA-PA(New-Albany) Request_Quote 1-570-928-8556/ 1-800-655-6865 Request_Insurance_Quote
1985
Transmission
Ford Truck F250 STOCK# #AI15847 AI15847 $Call Bollman's Auto Salvage USA-PA(Saxton) Request_Quote 1-814-635-3203 Request_Insurance_Quote
1987
Transmission
Ford Truck F250 RUNS AND DRIVES NOTE 120390 $Call Andrews Auto Salvage USA-PA(Eldred) Request_Quote 814-225-4646 Request_Insurance_Quote
Pastor Scott K
Oct 28, 2018 10:24 PM
blk88f250lb
May 9, 2008 08:30 PM
kbddbd
Jun 5, 2005 06:20 PM
bowlerman
Jun 2, 2003 12:07 PM
