tips on engine cleaning
Old Sep 20, 2014 | 08:17 PM
shuey24's Avatar
shuey24
Getting ready to clean the engine, read alot of material, but would like some tips from those who have done it.
Old Sep 20, 2014 | 09:30 PM
timbersteel's Avatar
timbersteel
Still under the hood or on an engine stand?
Old Sep 20, 2014 | 10:16 PM
Truck Guy99's Avatar
Truck Guy99
What he said^^^^
The best stuff I've found thus far is gunk heavy duty gel. Took baked on inch thick grease on my trans right off. Whatever you do don't get it in the intake and if it's a long block but still on a stand don't get it in any of the exhaust ports
Old Sep 21, 2014 | 06:38 AM
shuey24's Avatar
shuey24
Under the hood
Old Sep 21, 2014 | 06:47 AM
joegeds's Avatar
joegeds
Cover the alternator, distributor cap, and air intake with plastic bags. Per the owners manual, those are the 3 main things that need to be protected while cleaning the engine.
Old Sep 21, 2014 | 07:38 AM
Briansshop's Avatar
Briansshop
Get the engine hot before you spray it down w/the GUNK. The longer you leave it on there the better it will do. The really stubborn stuff will require a brush and some scrubbing. I don't cover anything with bags BTW.
Old Sep 21, 2014 | 08:32 AM
subford's Avatar
subford
Remove the PCM Computer plug and put fresh dielectric grease in it. Put the plug back on and then try not to get any water in the area of the PCM Computer plug.
Others have not done this and had to replace the PCM Computer after bay cleaning. As the PCM Computer put smoke in the cab after trying to starting it back up.
KIDkiser
Mar 14, 2016 02:58 PM
mongo75
25
Nov 30, 2009 03:35 PM
AntiGrav118
General Automotive Discussion
Oct 15, 2004 02:04 PM
93XLT150
13
Mar 22, 2004 09:32 AM
balucas
Jun 7, 2003 12:24 AM
