Unofficial Modification Thread
Old Sep 9, 2007 | 07:43 PM
  #91
lukecline's Avatar
lukecline
nope didnt have gauges in the modded truck.
Also added gauges to the 97 2wd tow truck. Its got AB split shot injectors, TW chip, Ford Reman trans w/ richter69 valve body, 7.3 ic, open down pipe and gutted ebpv.
Old Sep 9, 2007 | 07:49 PM
  #92
powerstroked162's Avatar
powerstroked162
I dont believe for one second you dont have gauges in your 7.3 Luke. Come on now, you might pull the woal over these rookies eye's but your not foolin me
Cowboy Steve
Old Sep 9, 2007 | 07:50 PM
  #93
lukecline's Avatar
lukecline
no, i didnt have gauges in the modded truck for about 2 months lol.
Old Sep 9, 2007 | 07:51 PM
  #94
glasseater's Avatar
glasseater
that doesn't seem very safe... lol
Old Sep 9, 2007 | 07:54 PM
  #95
powerstroked162
Cowboy Steve
Old Sep 9, 2007 | 08:00 PM
  #96
lukecline's Avatar
lukecline
I wasnt towing with it......
very much LOL
Old Sep 9, 2007 | 08:14 PM
  #97
glasseater's Avatar
glasseater
very much LOL
wow... just wow... haha
Old Sep 9, 2007 | 08:39 PM
  #98
lukecline's Avatar
lukecline
You get to a point when you have a pretty good idea how hard you can run something. I wasnt trying to pull 20k lbs up a mountain, mainly a lightly loaded goose neck around flat ol ks. After i got gauges i discovered that the egt's were never a problem at all.
Old Sep 9, 2007 | 08:48 PM
  #99
glasseater's Avatar
glasseater
that's good to hear
Old Sep 10, 2007 | 10:13 AM
  #100
Neal 97 250's Avatar
Neal 97 250
I agree with glass. TW chips are awesome and will roll the coal when you want to and just be a normal truck if you have to.
Old Sep 10, 2007 | 12:53 PM
  #101
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Neal did I miss something?, about what were your results with the TW 6 p chip? do you have a link of it?. And with the chip do you still have the 10K mod?. And what are the 6 positions?
Thanks.
Old Sep 10, 2007 | 01:07 PM
  #102
Neal 97 250
Here is the link.
http://stores.totaldieselperformance.com/StoreFront.bok
I got:
economy- better than stock but no smoke
high idle- around 1200 RPM's
light pull
heavy pull
40-50 HP
70 HP
I still have factory injectors so that is all the power I coud get from it...for now. The 70 setting made a huge difference in the truck. If you order from him he will give you anything you want. You can custom select what you want and have him put them on the chip in the order you want.
Yes I still do have the 10K but that is just because I have been too lazy to remove it. He said that it is not necessary with his chips.
Old Sep 10, 2007 | 01:33 PM
  #103
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
OK, thanks, and what is the difference between light and heavy pull if you already have tried? what about the EGTs compared with stock? and economy gives you more MPG?
Old Sep 10, 2007 | 02:15 PM
  #104
Neal 97 250
Economy does give you better MPG. I have not pulled yet. With stock injectors the EGT's are not that much different. Maybe a little higher with the 70 HP but not much. Light and heavy pull are because I told him I pull 15,000 and 6,000 lbs so he gave me both.
Old Sep 10, 2007 | 03:16 PM
  #105
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thanks, when you have more results, post them please.
