Putting a new comp wheel in . . here's a question.
Well can't get even a flex on that bottom bolt. Not enough room to get the length of the socket plus the end of the flex in there. It took me 20 minutes to get everything else off and I've spent 3 hours between trying to get that last one and running around for tools. I managed to get a wrench end on it and broke it loose but can't turn it far enough to get the wrench to reseat. Can't imagine how I'd get that bolt back in if I did get it out.
What else do I have to do to get the whole turbo off? 4 bolts in a square at the back close to the firewall (is that the up pipe?) and then the pedestal bolts? Am I going to need orings and gaskets or whatever if I do that?
on
to get the turbo off yes the 4 bolts/nuts on the up-pipe collector and then 4 pedestal bolts. the pedestal bolts are 5/16 12 point and the 2 nuts on the collector are 15mm and the bolts are 13mm. you will need new o-rings to put it back together. they are a standard size so you should be able to bring them to a hardware store and match then up.
Originally Posted by ltfox
When I changed my wheel on my 94 I had to pull the turbo clear off. sucks huh!!!
Back to my first question. For those of you who have replaced the wheel, is there RTV sealing the compressor housing or an oring or what. I'm positive mine has RTV. The seam looks just like the edge around my rear diff cover where a little squeezed out when the bolts were tightened and it feels like cured RTV too. In all the reading I've done on this I've seen nothing about using anything to seal the halves back together. What's up?
Keep in mind I haven't been able to take it all the way apart yet.
Check this guy out, this is who is going to do my turbo very soon. Hes a cool guy. I think the RTV is not the factory way. This guy has all the seals for your turbo, and I beleive that there is a large gasket that seals the two halfs.
http://stores.ebay.com/Rons-Turbo-Se...Q3amesstQQtZkm
BTW, his name is Ron and he will answer ALL of your questions if you give him a ring.
