Head light switch removal - 1949
Old Jun 17, 2007 | 07:41 PM
john fin's Avatar
john fin
Whats the trick to remove the headlight switch on a 1949 truck. Most switches I have seen use a button to remove the shaft but this one does not have one.
Old Jun 17, 2007 | 09:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You do have one, don't you?!
Old Jun 17, 2007 | 09:45 PM
tip49's Avatar
tip49
Switch removal
As stated , you should have a release button on the switch assembly that releases the shaft from the assembly.
Tom
Old Jun 17, 2007 | 10:42 PM
galaxie641's Avatar
galaxie641
How is the choke **** supposed to come off? I've looked through the shop manual a few times and never come across anything about taking either out.
Old Jun 17, 2007 | 10:48 PM
4tl8ford's Avatar
4tl8ford
Choke **** unscrew the nut, pull out.
Lite switch, pull switch **** out, twist shaft, half turn until you fell it give, repeat.
Old Jun 17, 2007 | 11:47 PM
mtflat's Avatar
mtflat
The early switches have a slot for inserting a small screwdriver blade. Depress the spring to release the shaft.
Old Jun 18, 2007 | 06:21 AM
dmptrkr's Avatar
dmptrkr
If you pop out the starter button you should be able to see the slot in the headlight switch where you insert a small screwdriver to release the shaft.
Craig
Old Jun 18, 2007 | 07:24 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
You know FTE is about asking questions, some may need to find another way of helping people or choose not to get involved in the thread. FTE is ABOUT asking and learning.
Old Jun 18, 2007 | 08:31 AM
4tl8ford's Avatar
4tl8ford
Not to start a contest but the 48 - 60 Forum has the most mechanical activity of any of the groups here. We are more likely to completely disasemble our projects and spend several years on a slow repair/rebuild.
We encourage all posters to get and be familer with both the parts/shop manuals.
The more an individual learns by themselves, the better they can expain their particular problem.
I am more interested in sharing my 50 yrs of expierence by explaining the "easier way" then telling someone what bulb to change when the light goes out.
Old Jun 18, 2007 | 09:24 AM
bobj49f2's Avatar
bobj49f2
I hope this helps:
Old Jun 18, 2007 | 10:40 AM
mtflat's Avatar
mtflat
Choke ***** are sometimes molded onto the shaft. Some are threaded on the shaft.
Old Jan 8, 2020 | 11:33 AM
Tlta29's Avatar
Tlta29
52 f1 headlight switch removal
I tried pushing the release button for the headlight switch and pulled and twisted as hard as I can and the stem will only come out about a 1/4" what am i doing wrong? what can i do to remove it?
Old Jan 9, 2020 | 03:27 AM
FortyNiner's Avatar
FortyNiner
Do you have the switch in the 'off' position? Brute strength isn't a requirement to remove the stem - don't want to damage things..
Old Jan 9, 2020 | 10:06 AM
Tlta29's Avatar
Tlta29
Yes i turned the **** all the way to the left (counter clockwise) then pushed the button in and can only get the stem to come out about 3/16" then it feels like its stuck on something.
The truck sat outside with no windshield for about six years.
Old Jan 9, 2020 | 10:19 AM
Tlta29's Avatar
Tlta29
Also now the **** just spins freely now.
richardbrust
Nov 20, 2013 11:26 PM
scrapyardking
Mar 27, 2008 04:45 AM
10-4 Crash
Dec 27, 2006 02:53 PM
Christopher2
May 8, 2005 09:44 AM
FedExguy2004
Electrical Systems/Wiring
Oct 24, 2004 10:16 PM
