keep the coils up front? where do i get bigger coil springs?? and shocks
yes keep the coils up front!!!! youll ride like **** if you dont...... and trust me it matters....even in a mud truck
there are custom coil makers but....run either the old 9" f150 springs or 8" fabtech 06 superduty springs.....or **** you could even run some of those big dodge springs.....but superduty springs are the biggest i know....around 28" tall,......as much as i hate to do it.......if you really want to run leafs here ya' go.....
thanks for all the help man, i would love to run the coils up front but who makes a coil spring that will lift the truck up another 10"? also i have a 7" skyjacker suspension on it now. what size is that coil spring? 7 inches?
ok....first off im going to assume you are running rocks since your on this thread....
a 28" coil spring is gigantic, they were 9" taller than my old 6" lift springs...that is about 15" right there....that is if you keep the stock spring bucket on your frame....if your drop your bucket, then thats just that much more lift
when you are mounting the spring on the rockwell side you can just have the coil bucket raised up a little giving you more lift...
im telling you if you run these springs (which you really dont need to) you will have plenty of lift depending on how you set it up....a 9" f150 spring would be plenty (about 24") think about it thats a big spring.....
