p1249 code w/ a Overboost Annihilator
Old Jun 5, 2007 | 12:02 AM
SBChero's Avatar
SBChero
i just got a p1249 but i have a Overboost Annihilator (regulator type). i have my red tube off the wastegate and on my intake clamp bolt.
is there something else that might throw this code? (assuming that my Overboost Annihilator is working correctly)
Old Jun 5, 2007 | 12:59 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Have you just installed th OBA or has it been there a while? If so, something must have changed as it works right or doesn't. Usually it works. Did you fool with the ****? The wastegate tube should have zip to do with what the map sees. Give the full poop on what you have done recently and what are your actual boost numbers and is it a mechanical gauge?
Old Jun 5, 2007 | 07:10 AM
Uzumati's Avatar
Uzumati
P1249 Wastegate Fail Steady State Test - doesn't have anything to do with boost or the OBA
Just a guess but I bet your red line is leaking.
Old Jun 5, 2007 | 07:31 AM
15 and 92 Dad's Avatar
15 and 92 Dad
My truck throws the same code, when I remove the red line (waste gate actuator) especially when pulling a load!
Rich
Old Jun 5, 2007 | 10:15 AM
SBChero's Avatar
SBChero
i added the OBA fairly recently, i use to get overboost codes hence getting the OBA. no mods recently, just that and a kwik filter. i do have a 6 pos chip, intake/4" exhaust, ccv.
unfortunately no boost #'s as my gauge is out for repairs.
that may be the case. i just have it plugged on that bolt for the i/c boot. it might not be sealing that good. ill try sealing that off w/ a ball bearing and see if i keep throwing the code.
Old Jun 5, 2007 | 11:36 AM
Tenn01PSD350
Good eye Alan. Guess I coulda looked that up but it was getting late.
Old Jun 5, 2007 | 07:43 PM
Strictly Diesel's Avatar
Strictly Diesel
FTE Sponsor
Alan,
I hate to differ with you, but P1249 IS the "Overboost" code. Per the Ford documentation:
DTC P1249 indicates that the PCM detected the turbo was overboosting.
Possible causes:
  • short to ground
  • plugged WGC hose or port
  • WGC solenoid
  • WGC actuator
  • WGC valve
  • damaged PCM
The other one people commonly mistake for "Overboost" is P0238...this one is "electrical" and not related to making too much boost.
DTC P0238 indicates a turbo boost sensor (MAP) circuit high input.
Possible causes:
  • damaged MAP sensor
  • MAP signal circuit short to power or VREF
  • faulty PCM
Old Jun 5, 2007 | 07:46 PM
Strictly Diesel
FTE Sponsor
SBChero,
If you clear the codes and the P1249 returns, you may need to back the regulator adjustment off a bit. Assuming that this is my kit (rather presumptious I know) and assuming that the units adjustment has not already been changed, back the **** off about 1/16th of a turn at a time ultil the problem goes away. Needing to adjust my setup is rare. If you'd rather have me readjust it, feel free to send it back and I'll dial it back in.
Old Jun 5, 2007 | 08:14 PM
Uzumati's Avatar
Uzumati
True Dennis but with his red line disconnected the code will set because the PCM is seeing more boost than it is expecting for the given load since the PCM thinks it is opening the waistgate. Not nessicarily seeing over the 22psi the OBA regulates to. IE. MAP seeing 20 psi boost but reference tables predicting 14psi for the situation.
Old Jun 5, 2007 | 08:50 PM
cbsword's Avatar
cbsword
haynes manual p1249= waste gate not detected.
Old Jun 6, 2007 | 01:40 AM
Strictly Diesel
FTE Sponsor
Alan...I'm not honestly sure that the system is that smart on these. I believe that the overboost is simply a preset "warning" value and not a table at all. I've run a bunch of trucks with the red line off and they still did set the SES until 24-26psi.
Old Jun 6, 2007 | 01:46 AM
Strictly Diesel
FTE Sponsor
Not sure how much I'd trust the Haynes manual for DTC descriptions. That's a pretty bad one if you ask me..."not detected how"? Did it fall off? Is it lost?
There are only 2 ways for the PCM to see anything to do with the wastegate. One is by boost pressure (either high or low) via the MAP sensor. The other is simply detection of an "open" or "fault" on teh wastegate control solenoid circuit (electrical). The WGCS is a dumb device, it offers no feedback to the PCM about whether it's in the desired position.
BTW, the official Ford description of P1249 is "Wastegate Fail Steady State Test".
Old Jun 6, 2007 | 04:23 PM
SBChero's Avatar
SBChero
dennis, it is one of your setups, and if the code does come back ill try adjusting it. i figured that it might have got out of adjustment some how (i didnt intentiolally change it).
i try not to get ahead of my self and start bashing products if the problem is something that i might have done (which is why i didnt identify the brand).
ill also plug up the red tube better and see if i keep throwing codes.
i appreciate all the help.
Madmaxz
59
Feb 1, 2011 07:00 PM
viperbluelx
16
Nov 3, 2009 06:03 PM
King0581
25
Apr 22, 2008 07:39 AM
HKusp
Sep 30, 2007 05:36 PM
kupaa
Sep 27, 2007 11:43 AM
