PSD Convert
Old May 23, 2007 | 11:11 AM
blackhat620's Avatar
blackhat620
blakerj10,
Maybe you are hearing the turbo vanes opening and closing.
Old May 23, 2007 | 05:28 PM
Beerstalker's Avatar
Beerstalker
Could it be the exhaust heat sheild rattling, or downpipe hitting the firewall?
Old May 23, 2007 | 11:21 PM
Jetmx's Avatar
Jetmx
blakerrj10- we are on the same page- sounds like we have exactly the same noise. Hope someone can chime in & help in more detail on a fix. The noise is definitely not high pitched.
ABS light still out. Think I'll wait to see if it come on again.
Blackhat- Based on the recommendation of others in this thread, I will go back to stock air cleaner asap. But are those "farts" OK ?
Old May 23, 2007 | 11:31 PM
blackhat620
Yep no problem, they are normal, you just don't here them that often with the OEM Donaldson system as it muffles the sound better.
Turbo "fart" is caused by excess pressure at the cool side of the turbo when you cut the throttle quickly when running hard. There is no waste gate on a VVT engine, so the pressure goes toward the path of least resistance, in this case back out the air intake.
Hope this helps
Taunya Richards
6.7L Power Stroke Diesel
45
May 31, 2013 03:42 PM
renoduckman
Sep 7, 2011 12:12 AM
GreyRanch
6.4L Power Stroke Diesel
118
Feb 12, 2011 04:09 PM
WillyB
N. California Chapter
18
Jul 27, 2006 09:27 PM
WillyB
Nevada Chapter
Jul 16, 2006 12:54 PM
