blakerrj10- we are on the same page- sounds like we have exactly the same noise. Hope someone can chime in & help in more detail on a fix. The noise is definitely not high pitched.
ABS light still out. Think I'll wait to see if it come on again.
Blackhat- Based on the recommendation of others in this thread, I will go back to stock air cleaner asap. But are those "farts" OK ?
Yep no problem, they are normal, you just don't here them that often with the OEM Donaldson system as it muffles the sound better.
Turbo "fart" is caused by excess pressure at the cool side of the turbo when you cut the throttle quickly when running hard. There is no waste gate on a VVT engine, so the pressure goes toward the path of least resistance, in this case back out the air intake.
