Sponsored by: Real Truck
Stealth Reverse Lights Mounted with pics
Old Nov 29, 2009 | 06:19 PM
  #256
bayou barataria's Avatar
bayou barataria
The circuit should already have a relay to handle trailer lights and all, mine does.
Old Nov 29, 2009 | 07:52 PM
  #257
SpringerPop's Avatar
SpringerPop
Yup. The 7-pin trailer plug harness has a black wire with a light green tracer that is for the trailer back-up lamps. It is isolated from the truck's back-up lighting circuit with a relay that "makes" only when the truck's back-up lights come on.
Hook up the additional back-up lights to that wire. Other side goes directly to a good ground.
That current is supplied from the same 20-amp fuse that supplies the trailer's running lights, too.
This arrangement allows the trailer electrical to be all kinds of shorted and corroded (it often is) and you only blow the trailer lights, and not affect the truck's lighting.
Pop
Old Nov 30, 2009 | 10:25 AM
  #258
bpounds's Avatar
bpounds
As long as we are clear this is the trailer circuit then I agree. The 18ga wire for the truck onboard backup lights is not nearly heavy enough for those driving lights. Just want to be clear for anyone who reads this in bits and pieces, since we're up to 258 posts.
Old Nov 30, 2009 | 11:24 AM
  #259
rotun's Avatar
rotun
Reads ***** rules!
Damn! That was alot of reading!!!!!!Oh well, now it's 259 posts.
Old Nov 30, 2009 | 12:00 PM
  #260
SpringerPop
But well worth it if it prevents you from making a mistake that shorts or overloads something, and lets out the smoke!
Gotta' keep the smoke inside the wires!
Pop
Old Dec 1, 2009 | 09:08 PM
  #261
bayou barataria
My point was for fordguy622 who just wanted them to come on with his reverse lights is that he does not need a switch, just hook them up in the back to the harness and ground them back there somewhere.
Old Dec 5, 2009 | 07:07 PM
  #262
5.4L to Freedom's Avatar
5.4L to Freedom
Just subscribing so I can continue showing these lights off to my friends! We are all going out to buy these same lights at the same time and are going to make a party out of installing them in our trucks.
Also, I will be using the switch vs. using the reverse lights as a trigger for the relay... this way they may be able to help me 'persuade' those pesky tail gaters to back off
Old Dec 6, 2009 | 12:31 AM
  #263
SpringerPop
So long as that tailgater isn't a LEO!
It's a sure way to get cited.
Pop
Old Jan 31, 2011 | 11:51 AM
  #264
dcacker's Avatar
dcacker
diagrams
Any reason the digrams from the original post are not showing up for me?
Old Jan 31, 2011 | 12:19 PM
  #265
brd7666's Avatar
brd7666
The pics aren't there for me either. This is an old thread. He probably removed them from wherever they were being hosted. You can start a new thread if you have some kind of questions.
Old Jan 31, 2011 | 12:30 PM
  #266
jdw1's Avatar
jdw1
I would just like to know what lights they are using without readding 265 post's!
Old Jan 31, 2011 | 12:41 PM
  #267
F250_'s Avatar
F250_
Here is a similar post in a different forum, but this one has pics of the same lights. Just run down to Post #20 in the thread linked below.
Stealth Reverse Backup Lights Installed - Lots of Pics! - Page 2 - Toyota 4Runner Forum
EDIT: Better Yet... here's a link to an Advance Auto page where you can order the same lights for $32 plus S&H.
Advance Auto Parts: Crystal Rod Fog Lights by Pilot - Part NV-534
Old Jan 31, 2011 | 12:47 PM
  #268
bpounds's Avatar
bpounds
These:
Blazer/Ultra white driving lights (UW3534) | Auxiliary Lights | AutoZone.com_
I wired mine to an 30A upfitter. Bearhunter had a relay so that they turned on with his stock reverse lights. I wanted full control of when they were on, and it simplified the wiring as well.
Old Jan 31, 2011 | 12:59 PM
  #269
BooDaddy69's Avatar
BooDaddy69
Originally Posted by Bear Hunter
This was a MOD that I wanted to do on the new truck for a while now. For this install, I wanted to keep everything as stealth as possible. I had been keeping my eyes out the right set of lights for quite some time. My original plan was to run HIDs out the back (which I still want to), but in the interim these lights will fit the bill.
Ultra White 55w fogs with crystal rod lens (found at Autozone)
JDW,
The OP posted exactly what the lights were in the original post....no need t oread 265 threads I have quoted it and highligted it above though.
Old Jul 4, 2011 | 12:05 AM
  #270
tbear853's Avatar
tbear853
Thumbs up
Pop
100% sure way I'ld say.
If it causes a wreck and some third party sees it and get's a tag number and we got it and get a BOLO oput and find it, and if that wreck results in $1000 damage or personal injury, it'll result in an additional felony hit and run charge ... at minimum.
