Stealth Reverse Lights Mounted with pics
#151
#157
#158
#160
on a halogen light bulb, there is a filament that conducts electricity and actually turns white hot. thats where you get the light from. just like a bulb in your house. An HID light had no filament, it has a ballast, ignitor, and actually arc's accross the gap inside the capsule. its like a flourescent bulb. the biggest difference is that an HID light doesn't draw nearly the power that a halogen bulb will. it also stays alot cooler.
OK, OTHERS, DID I SAY IT RIGHT KINDA OR DID I SCREW SOMETHING UP???
#162
#163
I've wired several vehicles over the years with back light relay setups like this and found one great trick for weather proofing the relay. Wire everything up with a touch of dielectric silicone on the contacts and make sure the lights work properly then get a can of plasti-dip (not the spray) and dip the wired relay into the stuff 2-3 good coats will do it. Once it's dry then screw the relay down where ever it's convenient and forget about it! I'm in the snowy-salt laden North and would rot off a relay every season until I started doing this. I've never had to replace a relay since - the whole thing is sealed and doesn't corrode.
#165
Originally Posted by Bear Hunter
This was a MOD that I wanted to do on the new truck for a while now.
Thank you for putting together this how to. I have been wanting to do this for quite some time and would have never thought of the diode trick.
Freaking awsome that I can use one set of lights to help with night time trailer hook ups (via my upfitter switch) and while reversing.
I used the same lights you did and even swapped the 55w bulbs for 100w bulbs prior to putting them on the truck. I also used the Velcro that you mentioned... but gotta say that I am not real confident of longevity, but will wait and see.
Installed in about 2 hours...
And on with reverse.
One thing that I learned during this install was that my reversing lamp wire was not the black/green that you refrenced in your install. It turned out to be the black/pink on mine. (2005 PSD)
Again thanks for taking the time to share your learnings.
Regards,
Duke
