1999 4.0 starting problems
Old Mar 26, 2007 | 11:19 AM
DBtoter's Avatar
DBtoter
My 1999 Ranger 4x4 with a 4.0 and auto is starting to have a starting problem. When I go to start it in the mornings it just wants to crank for a while and then maybe fire. I started cycling the key a couple of times and it will usually fire after the second key cycle but seems to be loading up on fuel and takes a few seconds to clear up. That leads me to think I am loosing fuel perasure in the rail maybe due to a bad check valve in the pump if there is one. Even after it is warm and I have just shut it off it will do it also at time and other times not it will start with no problems. Any ideas this site has helped me many times before and I need help again. There are not any trouble codes present.
Old Mar 26, 2007 | 05:20 PM
fflintstone's Avatar
fflintstone
Your in luck. there's a thread describing your trouble.
https://www.ford-trucks.com/forums/594859-iac-s.html
Old Mar 26, 2007 | 05:22 PM
fflintstone
Oops, wrong thread. Here's the right one
https://www.ford-trucks.com/forums/5...-starting.html
Fred Furrer
30
Sep 8, 2015 09:08 PM
Lonzo
Jul 2, 2014 09:01 PM
350harleyedition
May 13, 2014 08:15 AM
Will5o5
Apr 26, 2014 04:14 PM
Crewcabber
Mar 24, 2014 08:24 PM
