94 F150 starting issues
Old Apr 26, 2014 | 11:45 AM
Will5o5's Avatar
Will5o5
I have a 94 F150 with a 302, 140k miles. The truck used to fire up with a tap of the key, now it has to be cranked anywhere from 3-5 seconds. It seems to help if I bump the ignition a few times, then it won't crank and it fires up like it used to. It runs completely fine, seems like the idle is getting a little rough though. Changed the plugs, fuel filter, battery. I don't think it's a fuel issue because it does it randomly hot or cold on either fuel tank and even after priming the pump by cycling the key a few times. Any advice would be helpful, don't feel like replacing a starter, thanks..
Old Apr 26, 2014 | 03:00 PM
subford's Avatar
subford
Why would you replace the starter?
It has nothing to do with your issue.
Sounds like you may have a bad check valve in one of the FDM or the FPR is not seating all the way.
Old Apr 26, 2014 | 03:05 PM
Will5o5's Avatar
Will5o5
Any way to diagnose? I know there's an issue with the check valve in the rear tank, it always pumps to the front.
Old Apr 26, 2014 | 03:51 PM
subford's Avatar
subford
Then you have a bad check valve in the front and not the back.
Maybe your whole problem.
Old Apr 26, 2014 | 03:56 PM
Will5o5's Avatar
Will5o5
Even though it has the issue no matter what tank I have it on?
Old Apr 26, 2014 | 04:12 PM
subford's Avatar
subford
It should run OK on the front tank and poor on the rear tank unless the rear tank also fills while on the front tank.
But anyway you have a problem with the front FDM and you need it fixed.
Old Apr 26, 2014 | 04:14 PM
Will5o5's Avatar
Will5o5
Ya the starting issue is on either tank, runs fine, I don't use the back one very much
Mbp002
2009 - 2014 F150
Apr 16, 2017 12:59 AM
xrsfsho
36
Dec 24, 2014 09:37 PM
Will5o5
Apr 26, 2014 11:55 AM
teejmac
1983 - 2012 Ranger & B-Series
Sep 24, 2010 07:47 AM
joelnkim
Sep 24, 2009 12:17 PM
