VSS location
Old Mar 22, 2007 | 03:47 PM
tcervi1028's Avatar
tcervi1028
VSS location
Went to auto zone the other day just in case they might have a vehicle speed senser. What they gave me doesnt go on/in the rear axle housing,it is located on top of the transmision? Is the one on the axle an ABS senser? I am having those kind of troudles,ABS light on,OD light frashing,speedo not reading till after 35mph...
Old Mar 22, 2007 | 04:03 PM
Pocket's Avatar
Pocket
The VSS sits on top of the rear pumpkin. Some places will call it the rear ABS sensor.
Old Mar 22, 2007 | 04:10 PM
ponch37300's Avatar
ponch37300
It is on the rear axle like pocket said. I don't know about the VSS but there have been alot of problems with aftermarket sensors. I prefere to use motorcraft replacement sensors, alot of times you can get them from ebay for cheap or from Ed at discountfordpartsaty2k.com.
Old Mar 22, 2007 | 06:40 PM
clintbonnie's Avatar
clintbonnie
I had the same problem with 99 F350 about a year ago.. Replaced the VSS with a Napa p/n 530780 (they call it a ABS sensor), top of rear end, for $10.49 (see napaonline.com ) and it been good ever since..
Old Mar 22, 2007 | 07:12 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Get it from napa (online if possible for ~$10) - i paid $22 at the counter - it's an easy swap if you've got somewhere warm & dry to use for about 15minutes - i had the same symptoms and that sorted me quick
Mich6.0
Jul 28, 2012 01:53 PM
v10man51
Mar 11, 2008 07:48 PM
CdnSoldier
Aerostar
Dec 11, 2006 07:02 PM
Rockstar
17
Dec 10, 2002 08:49 AM
jrsbronco
1978 - 1996 Big Bronco
Mar 4, 2001 03:07 PM
