Air Intake
Old Mar 27, 2007 | 12:57 PM
  #31
Izzy351's Avatar
Izzy351
Originally Posted by MTMike
I tried 4 inch PVC and it would not fit the filter - either inside it or over it.
mike in montana
Regular PVC pipe is 4" ID, which is what the filter & intake tubes are. I was able to get mine together without an adapter. Look for couplers, not pieces of pipe... Not sure which size you'd need, but I know regular 4" pipe won't do it. Maybe someone else can tell you which couplers they used...
Old Mar 27, 2007 | 01:09 PM
  #32
MTMike's Avatar
MTMike
I just put the Intake hose over the filter - seems to be holding fine. I suppose any 4 inch OD pipe would work.
mike
Old Mar 28, 2007 | 05:02 PM
  #33
StanleyZ's Avatar
StanleyZ
Talking
Yes, use a coupler thats 4 inch Outer diameter. I took a tape measure to the home depot and measured till I found one. I forget what size pipes it couples but it is about 1/8th inch thick so you lose a little of the 4 inches on the filter air intake hose but not much and surely not enough to matter. It's not brain surgery, is it?
fordtruck661
Oct 22, 2011 08:44 PM
jh818
Modular V10 (6.8l)
Jan 25, 2011 07:54 PM
natem8301
May 13, 2009 03:31 AM
Orezona
Jan 15, 2005 02:30 PM
