PVC pipe is measured on the inside diameter, so 4" PVC pipe can be different ODs depending on the schedule. The 4" I found was very thin, so it worked. Don't know about the 6637 side -- it might end up just as tight as the stock tube fitting around the outside of the filter neck. I'll go check it now and see if it will go in...
Okay, so the piece I have is "3000 pound crush PVC sewer pipe", no schedule is indicated on it. It will not fit into the 6637 -- not a chance. It worked well for replacing the CCV coupler though, like I mentioned. It looks like 4" OD is what you need for that filter.
SAk, the fit between the exhaust pipe and intake tube is pretty good. Not too tight, not too loose. The way mine had to be cocked at an angle, it actually gave me a really tight seal, especially with the hose clamp back on it.
I went and measured the piece for my Cummins. It is fairly thick. I said that it was 4"to 3" reducer, but the small side of it has an o.d. of 4". I put a 4" piece inside the bigger end of the reducer to attach the filter to. It as an o.d. of 4.5" which is perfect for the filter I am putting on the Cummins since it's opening is 4.5". I bet that could find something similar to work for the 7.3. I like the PVC because I can paint it and the engine cover to match the truck paint.
If you have to have the adapter, then I would use the 4" OD exhaust pipe. It will be much thinner than PVC (keeping restriction to a minimum), and it doesn't have to show (no need to paint). The filter & intake tube would be flush against each other.
In my case, the white PVC replacing the CCV coupler is okay unpainted because my truck is white.
The concern about the intake tube coming off the filter without using an adapter is valid, but after a couple weeks of checking it for tightness, it's finally settled down. The first week I noticed the clamp loosening up, but I'm pretty sure that was because I was afraid of clamping down too hard on the filter. It hasn't moved and hasn't gotten loose since I torqued it down a bit more. I think it'll be okay like it is. YMMV...
SAK this thread has pictures of the 6637 that was on my truck. If you have a 99.5 or later you don't need any pipe to make it work. The boot clamps directly to the shoulder of the filter.
Izzy351 I ended up buying a piece of 4" exhaust at Covington Diesel on 98 in Panama City that has a 45 degree bend. It will never come lose once tightened
Reason: spelling
It is a 2002. I have the PVC because I might use a bigger AMSOIL filter(4510) with a 4.5" opening instead of 4". I might go with the 4090 though, and it has a 4" opening.
What is the CCV coupler that you replaced w/ PVC??
I just installed mine yesterday. Used a piece of connector PVC from Home Depot Plumbing Department. The OD is 4 inches and the conector is about 5 inches long, it fit great. Put a new clamp on the filter side. I couldn't get the 6637 to go in the stock hose at all, both are 4 inch ID (2001 model). PVC is a connector and is about 1/8 of an inch thick so I gues I'm losing some capacity but I just can't imagine it's enough to make a difference.
I am going to install the Amsoil eaau 4510 filter this Saturday. It has a 4.5" opening, so I am going to use PVC to connect with the stock intake tube. Will report back Monday, and maybe have some pictures.
Mine's still tight, and I don't need a bend. Are you in PC??
Ok! I am no pro at Filtration....But that Amsoil Filter only has a 4.5" opening and then you are gonna use PVC pipe......I may be wrong but you are kinda korking down the intake in that area and I would think that would cause some performance loss or atleast no gain. Well I hope It works out and if not atleast you have better filtration than the factory airbox and filter.
Has anyone tried using a piece of 4" PVC? I have a local diesel shop that I think can get me a piece of exhaust for nothing, but just in case. How snug is the fit between the stock tube and exhaust pipe?
I tried 4 inch PVC and it would not fit the filter - either inside it or over it.
