Cabin Air Filter?
Old Oct 21, 2011 | 07:18 PM
fordtruck661's Avatar
fordtruck661
Cabin Air Filter?
Is there a cabin air filter in a 2000 F250? Getting ready to change oil/filter, air filter and fuel filter so I figured I would see if there is a cab air filter.
Old Oct 21, 2011 | 07:20 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Nope. There is some speculation there there was going to be one, and that some have one, blah blah blah..... Apparently there are SOME out there with a filter. But there are VERY few. So few most people at Ford dont even know about it. But I have seen pictures of ones with a filter.
So to answer your question. No.
Old Oct 21, 2011 | 07:44 PM
fordtruck661
Well that also explanes why I found advanced auto parts sell cab air filters. That is The reason why I started thinking if there was one I did not think there was one.
Old Oct 22, 2011 | 05:27 AM
Supercab's Avatar
Supercab
The cabin air filter assembly is available from Ford as far as I know. I had asked a few years ago this same question and someone provided a part number for the "kit" and it is aparently easy to install so you can then use the filters available at your local parts store.
Old Oct 22, 2011 | 08:44 PM
TerryB99's Avatar
TerryB99
For my 2000 Navigator, the kit consist of a template to help cut out a small rectangle of plastic. The other part is a cover to put over the filter. The kit is no longer available.
What I did was pull the plastic under the dash behind the glove box. Found the rectangle of plastic and cut it out. Slid in a filter, and instead of the fancy cover, used a piece of duct tape.
smokersteve
Jul 4, 2011 05:28 PM
pullen plowen
Apr 11, 2004 09:31 AM
treb
1983 - 2012 Ranger & B-Series
Aug 22, 2003 04:19 PM
Fordcr
May 28, 2003 02:08 PM
