Sponsored by: Real Truck
Good Train Horns??
Old May 2, 2007 | 01:48 PM
  #121
riggz's Avatar
riggz
Since this thread is current, I thought I'd ask in here instead of making a new thread.
I want to install 1-2 Grover Emergency air horns. I will be using them for responding to fire/ems calls in my truck. I'd also like to be able to air up my 315/75R16 tires to 50psi. I don't want to spend a LOT of money so if anyone can point me in the correct direction on what size tank and compressor I will need. Thanks!
Old May 2, 2007 | 03:00 PM
  #122
Green_Dually's Avatar
Green_Dually
I have the 5 gallon tank with the viair 380c,so far its great.It works my MK1 train horns.And airs up my stock tire to 60 psi in about 1 minute.
Like i said it works great for me,and you can get the compressor and tank for about $250.00 on ebay.
Old May 2, 2007 | 03:06 PM
  #123
riggz's Avatar
riggz
how many horn blasts do you get out of that 5 gal. tank?
Old May 2, 2007 | 03:27 PM
  #124
Green_Dually
Ill get about a 10 to 15 second blast.
Old May 2, 2007 | 04:18 PM
  #125
riggz's Avatar
riggz
hmm ok i'll only be doing short 1-2 second blasts maybe every 15-30 seconds. so that setup should be ok for that?
Old May 2, 2007 | 05:31 PM
  #126
dcsmith's Avatar
dcsmith
Pressure Gauge
Originally Posted by Exposed
I finally got all the parts ordered yesterday for my train horn setup. Below is what I ordered.....
Seige Engineerining..
Kong MK1 horns
Safety Valve
Pressure Gauge
Hornblasters..
Pressure Switch w/built in relay
12 Gallon Tank ( I have not seen pictures yet from JK2404 but he has two of them under his Super Duty.. so they should fit)
4x4 Connection
ExtremeAire Severe service air compressor 3/4" HP 4 CFM Free
Egauges.com
AutoMeter Phantom Series air pressure gauge
I will get the 1/2" ID commerical hose/fittings from Grainger. Hopefully we be here by the Friday or Monday. I will start fabricating brackets and wiring this weekend... Work on the wiring schematic for my setup today....
Hopefully will be a kick butt system when done...
Exposed; Will that pressure gauge go to 200psi or more?
http://www.dakotadigital.com/index.c...rod/prd388.htm
Old May 2, 2007 | 06:36 PM
  #127
Exposed's Avatar
Exposed
The pressure gauge is good for 150 PSI. That is the working pressure of the compressor I am buying. I figured with full 1/2" ID hose from tank (12 gallons) to valve and then to the horns, should be plenty of flow....
Old May 2, 2007 | 06:40 PM
  #128
Exposed's Avatar
Exposed
Nice digital gauge.. I considered buying one like that but bought the AutoMeter because my fuel gauge to the big tank is the same. I hated to buy both gauges since the other one is fine.... Also the dash in the truck is not digital so thought it would look better matching...
Old May 2, 2007 | 06:56 PM
  #129
Green_Dually
Correct
Old May 3, 2007 | 04:53 PM
  #130
Exposed's Avatar
Exposed
Enough Room????
JP2404, Did you ever get a chance to post your shots? I am trying to figure out how you have mounted those two tanks.. That tank is 9" wide, 12 1/4" tall, and 44" long. Looks like it is going to hang down too low to me. I was assuming you mounted them under the cab and not under the bed.... I have the tank on the way and now getting a little nervious about it fitting now.... I was going to fabricate some brackets tomorrow afternoon. I am expecting the tank to be here tomorrow...
Thanks.....
Old May 3, 2007 | 08:14 PM
  #131
Bevis3's Avatar
Bevis3
When i get around to finish buying the parts, I'm gonna use a floor mounted foot switch, like we use in our ambulances (Airhorn and Federal Q)
Old May 3, 2007 | 08:21 PM
  #132
TNT in Round Rock's Avatar
TNT in Round Rock
hey Bevis .. i'm used to using a foot switch like you .. what I actually use for my truck though is a switch used for hand controlled trolling motors called a Big Foot. It's pretty cheap, and very durable - made to be stomped on all day with heavy amperage going through..it's more than you'll ever need ! .. here, take a look : http://www.basspro.com/webapp/wcs/st...=SearchResults
Old May 3, 2007 | 09:08 PM
  #133
riggz's Avatar
riggz
your ambu's have Q's?
Old May 4, 2007 | 05:27 AM
  #134
Exposed's Avatar
Exposed
Floor Switch
That is a good idea.. I was debating on putting a toggle switch between main horn and the air horns from the steering wheel but hate to mess with the truck wiring... I guess your can screw the floor switch down to the floorboard to keep it in place....I will check that out..
thanks
Old May 4, 2007 | 09:40 AM
  #135
redford's Avatar
redford
FTE Leadership Emeritus
You also need to be concerned about the recovery time. You may get 8 two second blasts from the tank, but how long until you're back up to pressure?
