Sponsored by: Real Truck
Good Train Horns??
Old May 4, 2007 | 09:45 AM
  #136
JK2402's Avatar
JK2402
I do have some pictures, but it seems I am not allowed to post attachements? Send me your email address and I will email them to you tonight.
Old May 4, 2007 | 11:28 AM
  #137
NorCalBusa's Avatar
NorCalBusa
Originally Posted by riggz
your ambu's have Q's?
And when they hit it, all the rest of the lights on the rig go dim...
Old May 4, 2007 | 06:33 PM
  #138
Exposed's Avatar
Exposed
Email Address
JK2402.. I send you a PM with my email... Got the tank fron UPS about an hour ago... Getting too late today to work on it. WIll start early tomorrow morning... Pictures will be great to compare where I am thinking it will have to go....
thanks
By the way, Kong horns sound great and plenty loud for me....
Old May 4, 2007 | 07:19 PM
  #139
riggz's Avatar
riggz
Originally Posted by redford
You also need to be concerned about the recovery time. You may get 8 two second blasts from the tank, but how long until you're back up to pressure?
yeah i was thinking about a viair 380c but may need to upgrade. i've started a thread about how to calculate the air usage, but haven't been able to locate the cfm each horn uses. i'm new to this air horn stuff so i'm not sure how it works with the psi levels and such.
can you have a tank at 200 psi and use some sort of regulator that drops it down to 110 psi to the horns?
Old May 4, 2007 | 10:48 PM
  #140
JK2402's Avatar
JK2402
Tried to send the pics, but delivery failed. Got another address?
Old May 5, 2007 | 02:53 PM
  #141
JK2402's Avatar
JK2402
Delivery failed again and I'm not able to PM you. Have a different account?
Old May 5, 2007 | 03:58 PM
  #142
TP83's Avatar
TP83
JK2402 try posting them on a site like photobucket or putfile and then send us a link or post them up on here through the site.
Old May 6, 2007 | 08:38 AM
  #143
Exposed's Avatar
Exposed
Email Address
JK2402, try this address...
same name as home account @mustangeng.com
See if you can email me at my work address...
... I got the tank mounted yesterday about midway between front and back seat, outside frame rails, on drivers side. It will be ok about an inch below the level of the running boards. I found a small drain which only sticks out about 3/8" below the coupling in the tank... That will be the lowest point.. Use existing holes in frame and fabricated a couple of brackets to carry it.. Working on plumbing today. Did get horns mount on top of my ATV storage box yesterday. That wil put horns about 6 inches above my headacke rack. Will be the highest point so will have to be careful going under any obstacles.... Should get all the plumbing done today except the compressor. Hopefully be here tomorrow.
Old May 6, 2007 | 09:04 PM
  #144
Bevis3's Avatar
Bevis3
Yes sir, sure do. International 4300 series.
Old May 6, 2007 | 09:06 PM
  #145
Bevis3's Avatar
Bevis3
Nope, not at all.
Old May 6, 2007 | 09:09 PM
  #146
TNT in Round Rock's Avatar
TNT in Round Rock
You're running the same chassis we are
Old May 7, 2007 | 03:05 PM
  #147
dcsmith's Avatar
dcsmith
I need some Guidance
There is something that has be worrying me since I got my horns/package (Siege: kong mk1, 200psi, 1/2 inch valve, 1/2 inch hose).
They sent the wrong fitting (3/8 compression type fitting with 1/2 npt). I needed the 1/2 compression fitting. I couldn't wait so I installed regular rubber hose (temporary).
Here is the thing: they sent the 1/2 inch compression fitting but it only had 1/4" pipe thread. Can someone explain why I would go back under that truck and replumb it and only end up with an outlet 1/4" in diameter from the tank. I called them to ask them just now. I have yet to speak with anyone at Siege-Engineer that has any idea what they are selling. I called now four time.
I am serious in asking. I have tried to locate a fitting at home depot. I bought a push to connect type 1/2 inch fitting. Got the fitting installed and found that the so called 1/2" hose is really 1/2 od so it wouldn't work with that fitting.
I don't know if I should take out the rubber hose and the associated quick disconnects or leave it.
Old May 7, 2007 | 03:10 PM
  #148
TNT in Round Rock
i did my own plumbing .. bought my fittings here locally at River City Hydraulics .. they have every hose to pipe size you can imagine .. everything I have is 1/2" hose and 1/2" pipe
Old May 7, 2007 | 03:22 PM
  #149
dcsmith's Avatar
dcsmith
Hydraulic Hoses
Hydroulic Hoses and fittings are the way to go. Thanks
You had mentioned a regulator before. Do regulators come in 1/2 inch? In other words if I leave my tank psi at 200psi and regulate the pressure down to say 150, am I reducing volume? The reason I'm tore up over the 1/2" verses !/4" pipe thread is volume or air speed I guess. I don't really know what is important in the big picture.
Old May 7, 2007 | 03:24 PM
  #150
TNT in Round Rock
no these are regular hose fittings... i'm just saying a hydraulic supply near you may have them.. Home Depot and Lowe's won't have what you want
