Dual tanks question, truck dies when switching
I have a 1992 F150 with dual tanks, the problem I have is when I switch to the front tank the engine dies, switching back to the rear tank it fires back up. I have seen a few different reponses to this topic on here. Does anyone have first hand experience as to what the problem really is? Any help will be greatful.
Tim
Tim
I had a 94 that did this. It was a bad fuel pump, sounds like you have the same problem. Good luck replacing it yourself, I believe the fuel pumps in these trucks are IN the tank, someone correct me if I'm wrong. One of the reasons I envy my brothers PSD, fuel pump in the engine bay ;-)
-Chris
-Chris
Originally Posted by 95Ford4x4
it's possibly a bad fuse or relay, i would use a test light and see if you are getting power to the pump on front tank. if it's getting power and not working then it's the pump.
You have a bad switch, wiring or pump in your front tank.
Here is a diagram:
http://i54.photobucket.com/albums/g9...el-sel1995.gif
Originally Posted by twurtz
also whe the truck sits in the garage there is fuel coming out of the charcoal canister ( i think that is what is called) what is causing that?
merbno
10-14-2014 05:36 PM
fordsrawesome
12-10-2011 08:00 AM
tseekins
40
09-09-2009 07:53 PM
