1996 Dual Tank Problem
Old Nov 11, 2013 | 09:55 AM
Big350's Avatar
Big350
I'm having problems with my 1996 F350, 460 with dual tanks. The rear tank pushes fuel into the front tank. After a fill up, I always run on the front tank first then switch to the rear tank. Once the rear tank is low, I switch back to the front tank which now has another 5 gallons or so added from the rear.
I just installed a fuel pressure gauge and have also noticed under full throttle, the front tank fuel pressure is only about 20 psi; however it's a normal 40 psi when using the rear tank.
So do I have a bad check valve in the from tank FDM? If so, is it best to replace the entire front FDM?
Thanks for any advice.
Old Nov 11, 2013 | 11:31 AM
Nothing Special's Avatar
Nothing Special
As I understand it, yes, the check valve in your front FDM is bad if you are filling the front tank while running on the rear. And if your fuel pressure is that much lower when running on the front I'd guess your front fuel pump is suspect as well. So I think it's time for a new front FDM.
stopp429
Feb 15, 2013 06:42 PM
lud04X
Dec 3, 2011 09:58 PM
quisp
Oct 26, 2011 04:07 PM
lahammer1
Jun 19, 2010 11:00 PM
rogersdan
18
Sep 27, 2006 12:21 AM
