4r55e 5r55e Ranger / Explorer Transmission Problems - CLICK HERE
Old Mar 11, 2017 | 07:56 PM
  #1006
jk080's Avatar
jk080
Transmission Rebuilder
Originally Posted by Peter Harden
I have a 2000 Ford Ranger with 197,000 miles on it. It's a two wheel drive, four speed, and four cylinder 2.5 liter.
It had no shifting or driving issues. Then suddenly one day both drive and reverse stopped working from a stop. Trying either from a stop and the transmission just slips. It tries to move forward but can't.
If I put it in second gear, it will get up to speed and then I can shift into drive. From there I can feel the transmission shift without a problem and can get up to normal road speeds.
The check engine light is on and the OD Off light comes on when it gets shifted into drive at speed. The OD light stays steady and doesn't blink.
The auto parts store checked the codes it was throwing and the there was one for poor presure on shifting solenoid c - which a google search tells me is shifting soleniod 3.
I dropped the pan today to take a look. There was no metal in the pan or on the catch magnet and the fluid wasn't burned. I can see where the shifting soleniod 3 is but I wouldn't mind some idea how to replace it before I start pulling bolts out. I can't find any videos or discussions that talk about this repair.
Also, it would be good to hear if others have fixed the same problem by replacing shifting soleniod 3. Is is too simple to think I only have to swap out the shifting soleniod?
Thanks for any advice!
Peter
Replacing that solenoid or any other one for that matter will not fix the problem you having with your transmission. That transmission should have reverse and a drive gear without any use of the solenoids, unplug the transmission and see if there is any change, if not something is broken.
If you have no reverse or drive but will engage in low or 2nd this is a indication of a failed input sprag. This can happen without warning and not create much debris.
Old Mar 21, 2017 | 10:52 PM
  #1007
Jimmie Jordan's Avatar
Jimmie Jordan
I
Originally Posted by fordboy_52
I am making a sticky for the numerous people with transmission problems. If you own a ranger or explorer you might be experiencing numerous shifting problems. If you would feel free to post here so we can have a running record of problems and multiple people who can assure that we have a correct fix.
I also have a tutorial available for the infamous " valve body " gasket. click the following link
Common Fix For 4r55e / 5r55e Transmissions With A Bad Separator Plate And Valve Body Gasket - Ford-Trucks.com
Thanks
Matt
I can't access your photos.
Old May 4, 2017 | 06:40 PM
  #1008
terrynbama's Avatar
terrynbama
I have a 94 Ranger, 4.0 auto. t is stuck in 2nd gear and will not come out. It is in 2nd gear when the shifter is in park, reverse, neutral, drive, etc. it only starts in park and neutral as it should but it is always in 2nd.
I tried disconnecting the shifter cable and manually shifting the tranny. It clicks through all positions but doesn't change gears.
Any ideas out there?
Old May 4, 2017 | 07:24 PM
  #1009
pawpaw's Avatar
pawpaw
Did the problem come about slowly over time? If so, check fluid condition & level & adjust level as described in the owner manual, or maybe if you've been having some building problems suspect a clogged tranny filter, if it's never been changed.
If the problem came about suddenly after some event, check line pressure & if none, suspect a pump problem.
A couple of thoughts for consideration, let us know what you find
Old May 19, 2017 | 12:19 PM
  #1010
motoz's Avatar
motoz
Posted in another area, sorry just found this thread
Hello,
I have looked over most all of the forum posts about trans issues with the ranger rand mine seems a bit strange.
No flashing OD light, no OBD codes.
Issue: in OD on or OFF while driving at steady throttle from 25 ish to 70 the transmission seems to stumble (feels like you are letting on and of the throttle for a split second) I thought about the TCC solenoid but the symptom is different Feels like a switch turning on and off constantly while driving at a steady speed.
Trans shifts fine up and down its just this annoying fluctuation at a steady throttle position.
Old May 19, 2017 | 12:51 PM
  #1011
nelbur's Avatar
nelbur
Could your A/C compressor turning on and off, be causing this feeling? Turn your A/C and defrost off to see if the problem is still there.
Old May 19, 2017 | 01:00 PM
  #1012
motoz's Avatar
motoz
no, a/c not used.
it does not feel like that, it feels like letting on and off the throttle for split second. or like going over road bumps.
but thanks
Old May 19, 2017 | 01:38 PM
  #1013
spooktn's Avatar
spooktn
could it be your torque converter is going bad ?????? pump not pump could feel like on and off throttle,,,,Maybe
Old May 19, 2017 | 01:48 PM
  #1014
motoz's Avatar
motoz
I think ill chump up and let ford diagnose it for me, thanks
Old May 28, 2017 | 11:25 AM
  #1015
Frasher's Avatar
Frasher
New member
I'm new to all this.I have a 2000 Ford Explorer 4.0 XLT OHV..had transmission problems and took to a guy and he replaced my 5r55e with a 4r55e..having problems. My teams code is D
Old May 28, 2017 | 11:26 AM
  #1016
Frasher's Avatar
Frasher
Transmission code*
Old Sep 28, 2017 | 02:09 AM
  #1017
wrenchtwister13's Avatar
wrenchtwister13
03 ranger 3.0l 2wd shift problems
I have a 2003 ranger 3.0l automatic
it has delayed shift into reverse and shifts hard in the forward gears really hard when you kick in to pass someone im thinking it is this valebody gasket problem what are your thoughts thank you on advance for the help
Old Sep 28, 2017 | 06:56 AM
  #1018
pawpaw's Avatar
pawpaw
Welcome to FTE.
Lots of unknowns.
If you have, or can come by the inexpensive ELM scan tool as discussed here, https://www.ford-trucks.com/forums/1...-scantool.html & running FORScan or the like software on the viewing device of your choice, have it scan the tranny computer for trouble code clues & post up All trouble code Numbers in a new thread, so you get help just for your problems.
Did the problem come about slowly over time, or suddenly after some event?
Are you using a licensed Mercon V tranny fluid, is it at the proper level as described in the owner manual?
What kind of condition is it presently in/does smell/look/feel ok/how many miles on the present fluid & filter?
How many miles on the vehicle/tranny?
Answers to these questions can begin to steer the forum in suggesting a useful trouble shoot/repair direction.
Old Sep 28, 2017 | 05:07 PM
  #1019
wrenchtwister13
Originally Posted by pawpaw
Welcome to FTE.
Lots of unknowns.
If you have, or can come by the inexpensive ELM scan tool as discussed here, https://www.ford-trucks.com/forums/1...-scantool.html & running FORScan or the like software to the viewing device of your choice, have it scan the tranny computer for trouble code clues & post up All trouble code Numbers in a new thread, so you get help just for your problems.
i got the truck like that no codes od light isn't blinking fluid is clean and full truck has 230k on it
Old Sep 28, 2017 | 05:28 PM
  #1020
pawpaw's Avatar
pawpaw
Ok good feedback. Do you know, or can you find out from the previous owner if it has a licensed Mercon V tranny fluid in it & how long the fluid & filter have been in there & did the shift problem come about slowly over time, or suddenly after some event for them?
Have you checked the tranny fluid level as described in the owner manual?
If all that is ok, check line pressure.
If all that checks out, come by the ELM scan tool & running FORScan on your choice of viewing device, have it take a look at the engine & tranny computers & the GEM for pending code clues. It can take an in depth look at engine & tranny things that can corrupt shift quality.
