4r55e 5r55e Ranger / Explorer Transmission Problems - CLICK HERE - Page 69 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Reload this Page > 4r55e 5r55e Ranger / Explorer Transmission Problems - CLICK HERE
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-24-2014, 06:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Transmission Guides
Print Wikipost
  #1021
Old 09-28-2017, 10:38 PM
1998Ranger25L153CID
1998Ranger25L153CID is offline
1998Ranger25L153CID is starting off with a positive reputation.
I subscribed to this thread a long time ago. I've gone through the original transmission, a Ford partial rebuild that lasted about a year, and then another partial rebuild that lasted 1 day of driving. Then finally a Motorcraft remanufactured unit that lasted a few years about 87,000 miles with proper 30,000 mile services. Then I bought one from a local transmission warehouse that is no longer in business that custom built it with whatever HD parts there was, which wasn't much or maybe nothing but it's outlasted the previous two rebuilds and doubled the time the Motorcraft remanufactured one lasted. I believe it's coming up close to 150,000 miles or maybe even 200,000 miles on it and as far as I can tell it's still good. The good thing is I got to keep the old transmission. I was wondering is it a rebuild a couple of friends could tackle with a fair amount of automotive experience combined and be confident that it may work? I've watched the videos and have the Ford guide. All it's doing is just sitting in my garage on a jack. I was told that at least the torque converter was bad when the transmission was replaced.
  #1022
Old 09-29-2017, 12:15 AM
pawpaw
pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
I forgot to say to put the TRS on the suspect list too, if line pressure checks out ok.
  #1023
Old 02-15-2018, 08:02 AM
stevebox28
stevebox28 is offline
stevebox28 is starting off with a positive reputation.
Exclamation
Can somebody fix the pictures in the article Common Fix For 4r55e / 5r55e Transmissions With A Bad Separator Plate And Valve Body Gasket? I planned on checking dropping the pan and inspecting the valve body this weekend and having the pictures would help immensely because I do not have a shop manual yet.
Thanks, Steve
  #1024
Old 04-21-2018, 10:02 PM
Chipmunk111292
Chipmunk111292 is offline
Chipmunk111292 is starting off with a positive reputation.
2005 Ford ranger 3.0l automatic
Hey I have an 05 ranger 3.0l v6 I just got from a friend. 230,XXX miled and the transmission shifts really hard when going into overdrive. Sometimes it kind of grinds when shifting in and out of overdrive. Also it kind of lags sometimes and takes longer to go into overdrive. Help please.
  #1025
Old 04-22-2018, 12:10 AM
pawpaw
pawpaw is offline
Welcome to FTE
EDIT: WOOOPS I missed in the title that it's a auto tranny?.
Was it doing this when the friend owned it, or did it begin doing this suddenly after some event?
Check the tranny fluid condition & fluid level as called out in the owner manual.
Has the tranny been serviced as specified with the proper fluid & filter changes over time?
Use your ELM scan tool to have it look for & display pending, or set, trouble code clues on the viewing device of your choice as discussed here https://www.ford-trucks.com/forums/1...-scantool.html & post All code Numbers, as they can help you & members focus your trouble shoot.
Some beginning thoughts for consideration, let us know what you find.
reggiedunlop
03-20-2017 10:39 PM
strokin'_tatsch
74
01-12-2017 11:46 AM
neonshaun
Ranger & B-Series
04-25-2016 10:03 PM
Gunny77
6.7L Power Stroke Diesel
31
03-03-2016 09:30 AM
Fomoko1
40
10-25-2010 11:28 AM
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
