rebushing pedals
Old Mar 6, 2016 | 09:43 AM
38 coupe's Avatar
38 coupe
Find a friendly local machine shop and have your parts rebuilt. The pin can be ground or turned between centers, grinding the diameter down to the diameter of the worn area. Then oversized bushings can be turned on a lathe to fit your shaft. Not hard work at all, just time consuming. You have to find a machinist who likes the work more than likes to charge a lot per hour...
Old Mar 6, 2016 | 10:31 AM
Rust Wrangler's Avatar
Rust Wrangler
That bushing is a tough one for sure. I did some searching and came up with nothing. You might call James at Joblot Automotive and check with him. Phone is (718) 468-8585.
Old Mar 6, 2016 | 11:37 AM
WQ59B's Avatar
WQ59B
Joblot is closed down.
Will pursue a local machine shop...
Old Mar 9, 2016 | 09:57 AM
Gear-Splitter's Avatar
Gear-Splitter
A cheaper route is to go with common plumbing bushings provided by your local hardware
store. There have been a couple of threads over on the HAMB with details. Try a "search"
on that forum and I will so the same tomorrow when I have the time.
Old Mar 9, 2016 | 11:49 AM
WQ59B's Avatar
WQ59B
Only Co I found that even mentioned the COE is Mac's, but their one lonely bushing is specifically listed for '38 only. Looking more & more like machine shop is the avenue. Great.
Looked thru HAMB, didn't turn up anything, will search it again.
Old Mar 9, 2016 | 12:41 PM
Rust Wrangler
Last time I talked to James at Joblot, he mentioned that I was lucky to get my parts when I did as they were preparing to close up for good. They were an amazing outlet for the toughest parts. I miss them already!
I've searched and searched for the parts you need to rebuild your pedal assy. and have come to the conclusion they are right in there with hen's teeth. I'd bet somewhere there is a dusty box on a shelf....
Just a thought, I've found many machine shop's can be persnickety about taking on projects like yours. Because of this, I've contacted gunsmith's in the past for this kind of work and had excellent luck. Even had one build me a 1911 while he was at it
myexpo02
29
Nov 1, 2017 05:27 AM
mv7fd
1978 - 1996 Big Bronco
Oct 29, 2016 09:18 PM
qman
Mar 16, 2016 10:18 PM
bassguy46
1983 - 2012 Ranger & B-Series
Feb 21, 2016 06:59 PM
jschluter
Feb 12, 2016 04:22 AM
