1978 - 1996 Big Bronco
79 bronco brake problems
Old Oct 19, 2016 | 09:17 PM
mv7fd's Avatar
mv7fd
So I have replaced darn near everything to do with the brakes on my 79 and still not that great when I start to push the pedal I can feel the brakes grab alittle but not much when the pedal gets all the way to the end it's like they are grabbing but I need more pedal to really make them grab could I have the wrong booster and pedal set up like they aren't the right ones for each other would that make it so it seems like I need more pedal room? I have a donor bronco that I know has the correct pedals and booster set up so should I just go ahead and swap it all out
Old Oct 20, 2016 | 06:21 AM
gatorfor88's Avatar
gatorfor88
B4 you just throw more parts at it you should do some checking to see whats wrong.What you describe could be anything from a master cylinder to a brake line. Or anything in between.
Old Oct 20, 2016 | 06:29 AM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Just do a hydroboost swap. its easy. ive done it to my 79. best thing ever
Old Oct 20, 2016 | 02:59 PM
mv7fd's Avatar
mv7fd
Trust me I haven't just thrown parts at it. I've bench bled all the air out of the new master I've bled all the air out I have no leaks no buldging lines the rears are properly adjusted I can jack the truck up all four corners push the brakes and they hold tight. My last and final thought is that the pedal isn't high enough to start with and that I don't have enough travel to get full brakes. I even adjusted the booster push rod properly
Old Oct 20, 2016 | 07:05 PM
mv7fd's Avatar
mv7fd
Could it also be a bad proportioning valve
Old Oct 20, 2016 | 08:10 PM
ManfredVonRichtofen
You couldve gotten the wrong vac booster. there are two types..one is fulcrum and one isnt.
Old Oct 20, 2016 | 08:12 PM
mv7fd's Avatar
mv7fd
The booster I have has a short rod coming out that attaches to a piece of metal then it attaches to the pedal the other booster would attach straight to the pedal
Old Oct 20, 2016 | 11:50 PM
Torky2's Avatar
Torky2
What size tires are you running? Something really big in outer diameter?
Old Oct 21, 2016 | 05:18 AM
mv7fd's Avatar
mv7fd
Running 33's
Old Oct 26, 2016 | 06:49 AM
lgfuller's Avatar
lgfuller
check the backing plates on the rear brake drums. I've run into problems on my 78 because one of the backing plates was AFU. it made for a fun bit of troubleshooting to find out why the brakes were always soft.
Old Oct 28, 2016 | 12:03 AM
EP145's Avatar
EP145
Check to make sure your rear drums are adjusted right that can cause low pedal.
Old Oct 29, 2016 | 09:18 PM
kenh4570's Avatar
kenh4570
+ one on the backing plates.
I had one with slightly loose bolts, elongated the holes allowing b. plate to rotate slightly.
Jim Reich
Aug 3, 2019 06:21 AM
grinnergetter
Sep 27, 2015 09:20 PM
rwjr
Dec 19, 2008 05:42 PM
muff
Oct 23, 2008 08:11 PM
tpaynesrport
Mar 31, 2004 12:21 PM
