thanx bowtiehatr.The connector uder the upper radiator hose going into the fan shroud is hooked up.Is that the one?There is 5 wires coming to it and four going into the fan area.there is a blue wire going nowhere.is this right?
i dont think so. the fan clutch is not that hard to replace, just no room to work. i would suggest removing the radiator as it makes it much easier. other than that, replacing the clutch is not bad all.
I have changed quite a few of these fan clutches for no-start conditions in the past, and seem to recall them not being covered by diesel engine warranty.
I might add that I have seen P0528 several times, and tend to disregard that code if it is not accompanied by a cooling system problem. It is not a code that will generate a CEL.
