SGII will check codes. With it plugged in, turn it on with key on engine off, and hit the SCAN button. It should reveal if any codes are present on the next screen.
Scangauge is hit or miss on displaying some trouble codes. Here is a x-Gauge code for DTC count. If it shows three (for example) and you only get one code with the scan button you know you have two more "lurking" in there and may need a better scanner to retrieve it. Most of the parts stores will scan for free, depending on which model of scanner they have on hand it may pull any remaining codes.
