DTC code
Old Jan 2, 2007 | 09:49 PM
jim6liter's Avatar
jim6liter
DTC code
I just decided to check for codes and came up with a P-0528.Fan speed trouble.Anything I can do to fix it?Thanks and Happy New Year.
Old Jan 3, 2007 | 06:12 AM
BowTieHatr's Avatar
BowTieHatr
check to see if your fan clutch is plugged up. if it is, your fan clutch has gone bad.
Old Jan 3, 2007 | 08:44 AM
jim6liter's Avatar
jim6liter
I dont get it.Plugged up?
Old Jan 3, 2007 | 10:18 AM
BowTieHatr's Avatar
BowTieHatr
your fan clutch is electronic. you have a connector coming from the side of it.
Old Jan 3, 2007 | 10:25 PM
jim6liter's Avatar
jim6liter
thanx bowtiehatr.The connector uder the upper radiator hose going into the fan shroud is hooked up.Is that the one?There is 5 wires coming to it and four going into the fan area.there is a blue wire going nowhere.is this right?
Old Jan 4, 2007 | 05:22 AM
BowTieHatr's Avatar
BowTieHatr
thats sounds right.
Old Jan 4, 2007 | 10:19 AM
jim6liter's Avatar
jim6liter
if the plug is all good.Could there be a problem with the harness or is it absolutly the clutch?
Old Jan 4, 2007 | 11:13 AM
BowTieHatr's Avatar
BowTieHatr
i would go more for the clutch than the harness. put to many of them on for codes.
Old Jan 4, 2007 | 03:39 PM
jim6liter's Avatar
jim6liter
is the clutch part of the 5/100,000?if not how much and how difficult to replace?thanks again.
Old Jan 4, 2007 | 05:16 PM
BowTieHatr's Avatar
BowTieHatr
i dont think so. the fan clutch is not that hard to replace, just no room to work. i would suggest removing the radiator as it makes it much easier. other than that, replacing the clutch is not bad all.
Old Jan 4, 2007 | 06:38 PM
CanadaGuy's Avatar
CanadaGuy
I have changed quite a few of these fan clutches for no-start conditions in the past, and seem to recall them not being covered by diesel engine warranty.
I might add that I have seen P0528 several times, and tend to disregard that code if it is not accompanied by a cooling system problem. It is not a code that will generate a CEL.
Old Jan 4, 2007 | 07:24 PM
jim6liter's Avatar
jim6liter
so what do you guys think?disregard the code all together.this wont cause any other problems?
Old Jan 4, 2007 | 07:29 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
It probably won't show up as a problem until summer.....I would think you would want to take care of it by then.
Old Jan 4, 2007 | 07:30 PM
CanadaGuy's Avatar
CanadaGuy
That would be my suggestion, keeping in mind that you don't appear to have any cooling system issues.
kbf1961
Oct 17, 2015 10:05 PM
IM1096
Mar 29, 2007 09:02 PM
christoph2069
1983 - 2012 Ranger & B-Series
Aug 23, 2005 01:41 PM
y2kexc
18
Jul 29, 2005 08:04 PM
swunderle
Escape & Escape Hybrid
Nov 7, 2004 03:59 PM
