BCP Mod done...
Old Dec 18, 2006 | 11:20 AM
F250tuff's Avatar
F250tuff
Originally Posted by BowTieHatr
well deepdoc, there have been some 6.0s run away. the ones i have read about have been due to alot of oil ingestion in the cac from a turbo seal or excessive idle time and the ccv system geeting clogged due to bad servise rates. i have heard it is rather interesting.
That would be a site to see, maybe on a Duracrap.
Old Dec 18, 2006 | 11:22 AM
BowTieHatr's Avatar
BowTieHatr
well they blow up at will neway lol
Old Dec 18, 2006 | 11:45 AM
EnviroCon's Avatar
EnviroCon
What MY did they start putting 110A alternators in? As far as I know the stock alternators are 130A in '04's. And given that the dual-alternator set-up is still being rated at 260A, I'm guessing the stock, non-extra heavy duty alternators are 130A.
Old Dec 18, 2006 | 01:00 PM
DeepDoc1's Avatar
DeepDoc1
Just talked to my dealer, he said if I don't have snowplow option, it's a 110A. Like bowtiehatr said, the largest oem I can replace it with is 140A for $267 + $75 core charge + $87 (1 hr) install. Hmmm - $429 is getting up there, but if I wanna play, I gotta pay.
Old Dec 18, 2006 | 01:33 PM
EnviroCon's Avatar
EnviroCon
Actually, what I'm more interested in learning is when (MY or particular production date)the change occurred. But you do bring up another question. How many different alternators (in terms of rated Amps) is Ford now offering on SD's? And with what package would they come with? All this helps when trying to answer someones question about whether or not their alternator can handle the load of some piece(s) of equipment they're installing . Knowledge is power.
Old Dec 18, 2006 | 02:05 PM
BowTieHatr's Avatar
BowTieHatr
the diesels have always been 110 amps. even in the 7.3s. with the dual setup, the primary is 140 amps and the secondary is 120.
Old Dec 18, 2006 | 02:49 PM
EnviroCon's Avatar
EnviroCon
Ah crap! So the specs that Ford publishes in their Body Builders Guides are wrong? I'm getting everything from 95A for a 2000 F-350 w/a 7.3 to 130A for 2001-2004 F-350's.
Old Dec 18, 2006 | 03:39 PM
BowTieHatr's Avatar
BowTieHatr
all of my books are 110 amps.
Old Sep 5, 2008 | 11:09 PM
sonneborn3's Avatar
sonneborn3
Originally Posted by DeepDoc1
<HR style="COLOR: #666666" SIZE=1>On '06 models there are 2 options for High Idle. Note belowThis is the easy step-by-step instructions to set up your '05 or '06 Super Duty to have a high idle option. This is for diesel trucks with the factory auxiliary upfitter switches. This procedure replaces the need in the older trucks to buy an AIC (Auxiliary Idle Control) module from Ford.
Will both of these mods work on an '04?
jake00
Jul 24, 2018 07:40 AM
PwerStroke99
May 25, 2017 07:48 PM
EFranzen
Dec 19, 2016 08:21 PM
ChiefM
Georgia Chapter
147
Sep 3, 2016 09:34 PM
302FROGMAN
Apr 15, 2007 06:04 PM
