Air duct cleaning?
Old Sep 12, 2010 | 01:13 AM
jake00's Avatar
jake00
Air duct cleaning?
Anyone ever get it done? is it worth it, or is it just smoke and mirrors? I've done several home remodeling (dry wall) projects, so I'm sure there' all sorts of goodies in my ducts...
Old Sep 12, 2010 | 06:27 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I think if a person suspected that they had dirty air ducts, it would be a worth while expense. I'm pretty sure that a lot of folks aren't as religious about changing filters as they should be.
I have the permanent filters on my system. Multiple payers of fabric sandwiched between steel mess screens and housed in a steel frame. I clean them every 5-6 weeks and take them apart and clean them annually.
Old Sep 12, 2010 | 07:30 AM
macgiobuin's Avatar
macgiobuin
I have had it done once. I think it was worth it....you would not believe how much crap 2 kids can throw down vents from birth to 15 years old!!! I will probably have it done again after another 15 years has passed.
Old Sep 12, 2010 | 09:47 AM
CretePumper's Avatar
CretePumper
If you have AC and have been doing reno's, I would recommend it. Doesn't take much to plug up the evaporator coil in the plenum, which when it's plugged up causes a few issues like freezing up from obstructed air through the coil, along with getting high temps in the plenum that will trigger the high limit switch and shut down the furnace while in heat mode and will generally need to be serviced by a technician to rectify it. Needless to say it's a lot less expensive having the ducts cleaned and keeping filters maintained.
Old Sep 12, 2010 | 10:50 AM
Charlie Bravo's Avatar
Charlie Bravo
How we used to do it before specialized air duct cleaners. Tape filters over each supply register. Place filters at the return duct at the furnace. Turn the blower on high and beat on the ductwork. You could take off the end caps and use shop vac with multiple hoses for length. Best, CB
Old Sep 12, 2010 | 06:47 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Even though we cover all returns with a furnace filter before starting a job it's not uncommon for us to have the ducts cleaned and sealed on a reno.
Often it's new owners, sometimes the same, but no one is going to take responsibility for the years of accumulated dust and crap in the ductwork before we got there.
I've never had a home with forced air heat, so I can't speak for the long term benefits.
Old Sep 12, 2010 | 08:15 PM
medhvac's Avatar
medhvac
i have done duct cleaning,and i think its a waste of money unless your return air duct is really dirty!supply duct does not get dirty!jmo
Old Jul 24, 2018 | 07:40 AM
pauladams's Avatar
pauladams
Duct Cleaning Lancaster experts have done cleaning really well at really very affordable cost.
seventyseven250
Dec 7, 2007 07:31 PM
e1p1
Oct 4, 2006 01:15 PM
Drover
Oct 11, 2005 11:53 AM
cigarxtc
Aug 31, 2005 11:45 PM
websthes
Dec 14, 2004 05:07 PM
