Gauge Installation
Old Feb 15, 2007 | 06:45 PM
  #46
raptor131's Avatar
raptor131
Originally Posted by Jocaren
Where do i need to connect my wires behind the lightswitch on my truck so my guages are only lit when the automatic lites kick on, now they only turn on when i turn the know all the way to the right, they wont run unless its in that position , i need help!
blue w/ red stripe it's actually right behind the dimmer panel, just pop it out look at the connector on the dimmer side and half-tap that wire
Old Feb 16, 2007 | 03:16 PM
  #47
BGMSPD's Avatar
BGMSPD
Thanks raptor131. Taking a look at the Banks elbow there doesn't seem like much of a flat surface to tap into. anyone know if you can tap the pipe (from the intercooler) just before the elbow?
Old Feb 19, 2007 | 07:45 AM
  #48
Lonewolftx's Avatar
Lonewolftx
Wink Well . . .
I wouldn't, it is heavy guage (black) plastic. Many get the accufab power intake elbow w/ the port already there. Mine is on the intercooler pipe before the intercooler. See gallery.
Old Feb 19, 2007 | 11:50 AM
  #49
dapgar's Avatar
dapgar
lonewolf, those look like ultra lites, if so, i like how they look. i was debating whether to get the ultra lite 2's or the original ones.
is there a reason you didn't put your EGT probe before the turbo down on the manifold?
Old Feb 19, 2007 | 12:32 PM
  #50
Lonewolftx's Avatar
Lonewolftx
Wink OK then . . .
They are Ultra lites. When I put them in they matched the KR guages pretty close w/ the green gell on the bulb. Also the II's weren't out yet.
Too much work to put probe on manifold. Yes, there is a differnece in temp reading but then again I really don't haul 10,000 lbs every day. I think too much is focused on where the hotest temps are and what the real need is for the reading.
I really don't think 80% of the folks here will note the temp issue in time when the diff betwen the two locations is only 300` to 500`. It is ur truck so do what you want . . .
Magnolia Tom
Mar 30, 2019 12:52 AM
Enomra
Oct 15, 2014 05:26 PM
jkey.bama
Apr 8, 2014 08:33 AM
oldbird1965
15
Mar 27, 2014 11:43 PM
