EGT probe
Old Apr 7, 2014 | 11:08 AM
jkey.bama's Avatar
jkey.bama
EGT probe
04 6.0 - Installing 4 pod pillar gauges (egt, fuel pressure, boost & oil pressure(just to fill the pod) in addition to my scan gauge II x gauges.
1. How far down the exhaust pipe (not drilling exhaust manifold) should I drill the hole for the egt probe/strap clamp?
2. Any easy test port or location for oil pressure sensor?
Thanks
Old Apr 7, 2014 | 08:37 PM
wait4it's Avatar
wait4it
Exhaust manifold would be better for drilling and taping EGT probe due to thicker metal and flater mounting surface. Just drill and tap with the truck running to help prevent blow shaving out instead of going in to the turbo. Use safety glasses!
I can't help with the oil tap, maybe someone will clime in soon.
Old Apr 8, 2014 | 08:33 AM
MisterCMK's Avatar
MisterCMK
Drilling and tapping with the truck running is pointless and a good way to burn yourself.
The probe goes on the bottom side of the manifold. Any shavings will fall straight down.
Don't grease the tap or drill either.
Sent from my Telegraph using IB AutoGroup
plgebbia
Jun 4, 2010 02:38 PM
Bluebronco85
Jan 31, 2009 03:54 PM
Benny2002
16
May 22, 2007 06:31 AM
legacy76
Mar 22, 2006 09:16 PM
TooMuchBoost
Nov 23, 2003 02:44 PM
