Egt probe install
Old Oct 14, 2014 | 06:56 PM
Enomra's Avatar
Enomra
Egt probe install
I remember a great write up on gauge install including the egt probe. I have searched and cannot locate it, I even searched the tech files. If you know where it is located please let me know. I am adding an egt gauge and the generic install does not cover correct wires to tap into etc.
Thanks in advance.
Old Oct 14, 2014 | 07:30 PM
KIDkiser's Avatar
KIDkiser
It's best to tap into the back of the drivers side exhaust manifold for an egt gauge.
Old Oct 14, 2014 | 07:52 PM
Ford_Fan1's Avatar
Ford_Fan1
Just did mine this weekend following this writeup. Remember to start with a small bit and work your way up to letter R drillbit to keep metal shavings small. when you are all done take a vacuum and suck out the debris from the hole. DO NOT coat your bits in any type of lube or grease as this will just make a mess.
Gauge Installations at DieselManor - 2003-2007 6.0L Ford Powerstroke
Old Oct 15, 2014 | 04:00 AM
Yahiko's Avatar
Yahiko
If you really inventive you could take some PVC pipe and a vacuum
and hook the hose up so that the end mates up to the manifold and
surrounds the bit. That way your pulling the chips out as you drill.
I never liked the grease idea myself and that is why I thought about this.
Sean
Old Oct 15, 2014 | 05:26 PM
Enomra's Avatar
Enomra
Thank you for the replies... That link helps a lot thank you.
dr67
Feb 15, 2016 05:52 PM
riverguideguy
Apr 24, 2013 01:00 AM
izzybird
13
Sep 6, 2010 06:14 PM
Sparkplugless
May 29, 2009 01:31 AM
cable666guy
Aug 27, 2007 05:30 PM
