Tps
Old Nov 21, 2006 | 07:51 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Tps
Am I missing something here or what? According to the OBD my TPS is acting up. Ordered one from Napa and it's not right... called ford and we crossed the numbers and they said it's the right part. Only they are telling me it is bolted to the injection pump...not the top of the pedal Don't know where the parts man is getting his info but for giggles I checked the pump and as I expected nothing....
Gave them the number off the sensor I pulled off the pedal, couldn't find it in the system. He did tell me I could get a pedal assembly for $330 but can't get the sensor at the top seperately. He couldn't even tell me what the sensor was for But argued with me that it is no the TPS. Guess I'm gonna have to order a pedal assembly tomorrow
Old Nov 21, 2006 | 08:01 PM
tjbeggs's Avatar
tjbeggs
yes its technically a tps. yes you need the whole pedal assembly and the part you got was for a mechanical indirect injection 7.3 diesel 94.5 and earlier.
Old Nov 21, 2006 | 08:02 PM
tjbeggs's Avatar
tjbeggs
the pedal assembly contains 2 sensors, one is the tps and the other is an idle validation switch. what is your truck doing that it needs a tps?
Old Nov 21, 2006 | 08:25 PM
79_250RangerLariat
I kinda figured from the F2TZ number on the part it was for the old IDI with the mech linkage. It's starting to flash the check engine and OD lights and have no pedal response. Usually after one press of the pedal it starts to work again. I'm also throwing a turbo boost code, but figuring it is from the TPS not reading right (will act like a upshift while pulling heavy loads up hill, lose power, down shift and crawl the hill). Reset codes a couple of weeks ago and it ran great till the lights started flashing again, same codes as before.
superrman77
13
Jul 15, 2012 12:37 PM
Abinsur
Nov 3, 2011 10:03 PM
BigRy
Sep 6, 2011 12:39 PM
crimpton
Nov 6, 2007 08:28 PM
79F150EFI
Jun 12, 2007 06:09 AM
