my ebpv stays closed till temps are up to N.O.T with this strait pipe its very noisy and i have no power when its closed..i unhooked the temp sensor in my air intake..it now comes on for a few minutes when i 1st start her then it opens up..and doesnt come on again..this i like cause going down the road my neighbors give me dirty looks when the ebpv is closed..and i hate running it with no power..i userly leave home when the temps just start to show up on the gauge..my question is..am i hurting any thing by keeping this heat sensor from in the air intake in my glove box till spring??? thanks guy's
i wounder if my sp diesel exhaust brake and t/c lock will by pass that for me?? i havent got it in yet..well for good any ways.i had it in but when i hooked it up it closed my ebpv and kept it closed..the only way it would open was too un hook the unit..i just sent it back for them to find out whats going on....i have the high idel on my tuner..so keeping it unhooked would be ok im guesing??
I dont think so most people remove the IAH and Plug the hole to open up the intake. It might take a tic longer to warm up the truck though. PDP Has an eliminator for the IAH code it is a resisted wire that will run from the relay to a block ground.
thanks alot alan..with my high idel it warms up plenty fast enouph for now..ill half to ask sp diesel if my brake will bypass that...i dont want to half to put a muffler on it..i did get a defuser for the ebps..would that have caused me problems??
