What sensor(s) control the EBPV opening?
Could it be the EBPV was open? The truck is straight piped so I doubt I'd hear the whooshing air coming out of the EBPV. What else could it be? The wastegate boost line is removed and plugged.
Does the EBPV always open during normal startup (even in warm weather)? Then close as the engine warms up? Or does it only open when the temp drops below a certain point. Could it be that there's another sensor that's going bad?
On the drive home (50 miles) I had the cruise set and the engine sounded like it was accelerating and decellerating on it's own. I was on a flat road, had the cruise set at 69 and I could literally feel myself getting pushed in/out of the seat as it was doing this. I could also hear the engine doing it as well......
Any ideas on this?
Could the feeling I was feeling be the EBPV opening and closing while I was driving?
Today the truck drove EXACTLY like it drove when I first drove it 8 months ago. It only got about 15K on the 6637 air filter and the fuel filter is kind of fresh. BUT, I filled up with some of that awesome ULSD last night! Maybe I have a fuel problem......
I guess I'll see how it goes the rest of the week. I get home too late now to work on it. I'll change the air/fuel filters this weekend to be sure.......
Thanks guys
Any ideas on this?
Thanks guys
I will have to look into surge issues for your driving question.
I'm going to check the speed sensor on the rear end. That was bad on my F150 and caused the surging while on cruise control. Funny thing is though, the surge thing hasn't happened in awhile. And more I think about, it only happened around 70mph. Once I was up to 75 it would stop. Maybe that sensor is bad. They're not that expensive. I'll see about getting one tomorrow.
The EBPV will close when you're driving on flat ground, unloaded when it's cold outside. That could likely be causing the sudden and sporatic loss of power you feel while driving.
The EBPV is open most of the time. The truck will cycle it closed and open every time you start the truck, to keep it from getting stuck in the open position. If it's cold outside, it will stay closed to help the engine warm up. Once the coolant reaches a certian temp, or it senses exhaust pressure, it will open. If it opens due to exhaust pressure, and the cooant temp is still low, it will close again once the exhaust pressure drops - when you let off the throttle.
The exhaust backpressure sensor is located on the front of the engine, right in front of the HPOP res, offset about an inch to the passenger side. It's behind the belt. There is a tube running from the bottom of it to the passengerside manifold. My guess is that tube is clogged with soot. Remove the sensor, clean out the tube, clean out the end of the sensor, and reinstall the sensor. I'll bet that fixes the problem of no power when you give it some throttle. However, if it's cold outside, the EBPV may continue to close on occasion when you're cruising on the highway.
So, the EBPV is open during normal driving. I assume open means that it keeps the flow of exhaust in the turbo and exhaust system, closed means it dumps the exhaust out before the turbo back into the exhaust? Do I have that right?
Could I check the function of it by unplugging it? Maybe unplug it and see if the surging goes away?
Thanks again
The carbon and soot cake on and harden so it is usually a must to remove to really clean it. The sensor comes off with a deep well socket just be sure not to apply any lateral pressure when breaking it loose. It can break and it isnt cheap.
The tube runs from just under the sensor to the passenger side exhaust manafold at the front. A crowfoot wrench works pretty well on the top since it is kinda tight and can be used on lower part also but any wrench will work for the lower.
Best way I have found to clean is spray with Braklean and use 0.95 weedeater line (Square kind) to run down the tube. 3 or 4 rounds with the braklean and line do the trick. Be carefull cleaning the sensor all you need to do is make sure the opening is free from obstructions. There is a diapham about 1/4" deep into the sensor you dont want to damage it.
In the summer when mine was clogged the only thing I noticed was the mileage dropped but when it is warming up now on cold mornings and the EBPV is closed it does rob power
Open - https://www.ford-trucks.com/user_gal...108336&width=2
Closed - https://www.ford-trucks.com/user_gal...108335&width=0
Follow Alan's excellent instructions for cleaning it.
You could unplug the EBPV to see if it helps. Default position for the EBPV is open. The plug for the valve is under the intake spider, on the front of the turbo pedistal. It's a two wire plug, with a metal clip on it.
Here is a picture of what you are looking for. Section 11-Engine Electrical , Wiring Harness Front View , #4 Hope this helps
http://www.nav-international.com.br/frame_master.asp?tipo=powerStroke&pg=manual_i/powerStroke/hs.asp
It's possible that the tube to the sensor could be plugged, or partially clogged, thus making the truck "think" the engine is just idling, therefore closing the EBPV so it would help it warm up.... Once the tube is open the truck will sense the exhaust pressure and work the EBPV accordingly.
FWIW, My dad's 02 hardly ever makes the whooshing sound. Only time we both know it did it was when we were in Toronto Canada and it was in the teens out.......
I cleaned the sensor and the tube. The sensor wasn't clogged, but it had some crud in there. Tube was fine. i took it off and it blew clean with one shot of brake cleaner.
What else could it be?!?!?!?
This morning I cranked it up. I hadn't ran it since Sat night. It ran rough for awhile (still trying to figure that one out too!) I drove out the neighborhood. Once on the road, I had it floored and it baaaaarely creeped up to 30mph. I mean it was LAME and DEAD!
Then all of a sudden, it took off like a bat out of hell....... It did this less and less until it was up to normal temp......
Who thinks my fan clutch is causing these problems?????????? I going to check it tomorrow and see if it's hard to turn while cold, then check it again once the truck runs right...... we'll see.....
