Rear End Width?
Old Dec 9, 2002 | 10:33 PM
youdog99's Avatar
youdog99
Rear End Width?
Old Dec 13, 2002 | 09:30 PM
gquinn8516's Avatar
gquinn8516
Rear End Width?
How wide a rear end do I need for my 56 F100? I want to put a 9" Rear end under it and put some 15" Wheels and tires that will give me good ride and traction.
Thanks
George
Old Dec 14, 2002 | 12:41 AM
mtflat's Avatar
mtflat
Rear End Width?
Direct swap for pickups '48 and newer is any 9" from 1/2 tons from 1957 thru '72. Depending on what it came from you might need to move spring perches or shock brackets, and may need to use caster shims to adjust pinion angle.
Drum face to drum face is 61 1/4" Housing stub to stub measures 57"
Old Dec 14, 2002 | 05:03 PM
ferguson777's Avatar
ferguson777
Rear End Width?
Additionally, there's;
1971 - 1973 Mustang (came in 8" and 9" but easy to tell apart)
(9" at least has the 5 on 4 1/2 pattern)
1989 - 1996 or newer Explorer. (some of these have disc brakes as well,I can dig it out if you are actually interested,but the gear ratios available for it are better for overdrive trannies)
(pretty sure it's the 5 on 4 1/2 pattern)
Somebody in here is using a Mopar end
(not a Ford 9" obviously, but gives you the 5 on 4 1/2 pattern)
Later,
eakanator
Jul 9, 2002 01:07 PM
DaleL
Dec 29, 2001 08:40 PM
lochpham
1983 - 2012 Ranger & B-Series
Jan 4, 2001 11:50 AM
autotech
Sep 18, 2000 01:23 PM
Sep 1, 2000 11:23 AM
