Sponsored by: Real Truck
"0 miles to Empty"
Old May 11, 2019 | 10:43 PM
  #76
maticuno's Avatar
maticuno
I've definitely noticed the lower the tank gets, the more accurate the DTE seems. On a full tank, though, it's way off. After refueling, it will say I only have 180 MTE, but I know I can hit over 300.
Old May 12, 2019 | 05:47 AM
  #77
Deuce40s's Avatar
Deuce40s
For the life of me, I don't understand why people use the DTE. It's only an algorithm. Just look at the gallons used. You know you have a 26 gallon tank or whatever, why would you wait until you have used 24+ gallons before stopping for fuel?
Old May 12, 2019 | 07:21 AM
  #78
Chuck's First Ford's Avatar
Chuck's First Ford
understand....
the fuel pump is inside the fuel tank. and NEEDS the fuel to keep the pump COOL...
on a hot day.. driving a good distance... going below 1/8 of a tank..
the fuel and the pump can go over 160 degrees... and can damage the fuel pump...
good money for a mechanic. and a tow truck driver...
this is NOT new news...
don't believe me... next time on a good distance drive and low on fuel .. put your hand on the underside of the fuel tank...
Old May 15, 2019 | 02:08 PM
  #79
ndnchf's Avatar
ndnchf
My 2015 Edge has a similar MTE display. It seems to work pretty we. I've only had my 2016 F250 for a week, but I'd like to see how accurate it is. Its a nice feature if it is reasonably accurate.
Old May 15, 2019 | 06:13 PM
  #80
dirthawg's Avatar
dirthawg
Originally Posted by Chuck's First Ford
understand....
The 6.7l trucks don't have a pump in the tank. It's on the frame rail.
My last truck....92F350 with dual tanks got 6 mpg towing and I had to refuel every 4 days running my business around town. I always ran the front tank until the needle hit empty. I even drove it till the truck was stuttering and chucking under WOT on a freeway entry ramp many times. Flip the switch to the full tank and all is good again. I drove that truck for 150,000 miles in the same manner and never once replaced the forward fuel pump. I did change the frame mounted fuel filter yearly and it was nasty dirty when I dumped the fuel back out the input side.
Old May 15, 2019 | 08:17 PM
  #81
Fefanatic's Avatar
Fefanatic
I question that theory. Every fuel pump in the tank that I have replaced (and that's all makes and models) have the fuel being pumped through it. Look at a in tank pump. The pickup sock is on the bottom and the fuel goes through the pump on to the filter and then engine. Even if it is at 1/8 tank fuel still goes through pump and keeps it cool. Air flowing past the tank whle driving will keep the fuel cool. That being said 90+% of the pumps that do go bad is from a partially clogged or clogged fuel filter. I can see a pump overheating when it is trying to pump fuel through a clogged filter.
Old May 16, 2019 | 10:52 AM
  #82
drew999999's Avatar
drew999999
I've had a 2013 F150 and how have a 2016 F350, with each having the 35 gal tanks. Both of them read 0 miles to empty right around the 31 gallons used mark. I've never been brave enough to go further, and really hate changing fuel pumps.
Old May 16, 2019 | 12:50 PM
  #83
maticuno's Avatar
maticuno
While every vehicle is a little different, most in-tank fuel pumps that have a fuel return line dump the return line right on top of the pump to help keep it cool, even if it is no longer submerged in fuel.
Old May 16, 2019 | 03:47 PM
  #84
TexasRebel's Avatar
TexasRebel
Gallons Used data wasn't provided when this thread was started. Does not exist on a 2008.
Old Sep 5, 2019 | 07:18 PM
  #85
mokragleski's Avatar
mokragleski
On a related topic, my 2017 Super Duty 6.7l had the issue with the 34 gallon tank. After traveling to California with my 5th wheel and nearly running out of fuel in the desert I replaced the fuel tank with a 60 gallon tank. Great move, super happy with my range, however every Ford dealer I go to refuses to change the DTE setting. I know if I manually double my DTE I am about right on, however I would like to change the truck setting so it knows the new fuel tank size. Is there anyone you can recommend in the Detroit/Toledo area that can do this?
Old Sep 5, 2019 | 09:42 PM
  #86
SnowPlowDriver's Avatar
SnowPlowDriver
Speaking of running out of fuel ,my neighbors co worker ran out during the Ferguson riots a few years ago. Police took him to get a can of gas and asked him if he was nuts.
Old Sep 6, 2019 | 07:45 PM
  #87
SuperDutyScaler's Avatar
SuperDutyScaler
Why are all yous running the tank that low for anyways
97flairside
2009 - 2014 F150
Sep 7, 2014 08:15 PM
TBigLug
Mar 4, 2014 01:10 PM
bigcountry25
Electrical Systems/Wiring
Oct 4, 2013 06:52 AM
A/Ox4
Dec 26, 2011 04:42 PM
Old Rust Bucket
Jul 30, 2007 05:29 PM
