Help with heated seats
At any rate when my wife gets home with the X going to try it out. Found a place on Ebay that makes replacement leather lowers and uppers and they have some good vidoes on how to remove the seats and take the leather covers off.
Again this is a video on how to take the seat out and replace the leather cover.
Remove
YouTube - 02-06 F250 Driver Bottom Part 1 of 2
Replace
YouTube - 02-06 F250 Driver Bottom Part 2 of 2
I twisted off two hog rings so I'll be able to re-install them. The big round lumbar support **** did not have to come off but most of the rest of the trim at the bottom of the left (outside) of the driver's seat did have to come off.
I am going to use 16 gauge aircraft wire for the jumper between the seat bottom and the thigh support heaters with shrink wrap over the entire section. Only the outside (left side of the seat) is burned through but I'm going to replace the jumpers on both sides while it's apart. I may put a piece of felt in that trench between the two cushions to provide a little protection for the jumper.
I'm a woman and I'm getting this done. Toughest part has been compressing the cushion to release the long plastic fabric retainer clip. It's helpful to have three hands for that part.
. My driver seat quit working... i know here in Cali it doesnt seem like a big deal but the 23 degree nights make it a must... plus the OCD to have everything in the truck work. Mine wasnt a bridge wire but one of the small grid wires... burned in two... resoldered retested and YAY! my butt will smolder now. Once again thanks to all for sharing their expert advice.
When I turn on the button (driver's side) I get the orange light, yet no heat. So I pulled the seat out, removed the seat cover and found no areas with burnt wires. I even removed the heating element from the pad and looked at with a flashlight on the back. When I tested for continuity I got a 0.001 on my meter. So I went ahead and replaced both wires between the thigh and rear heating element (soldered an 18ga stranded insulated wire). I now get 0.000 on my meter. Still no heat! So tonight I also did a resistance test and got 001.5. When I tested the pasenger side (since it works according to my wife) I also got 001.5.
Any ideas what to check next? Now it's a mission! God forbid it would be just as simple as finding a burnt wire, replacing it and now my heater works.
Forgot to mention. Before I completely put the seat back together I took the botom heating element and the seat back out to my truck (along with the button) and did a test. I was able to test the wires at the back of the element where they come in and where I soldered in the new wires and was get about 11.5 volts.
Did you ever figure this out? I have the exact same issue. I see no breaks, and when I do the continuity test at the switch, i DO have continuity. I tried swapping the switch from the passenger side and the drivers side, passenger side still works, driver side does not!
Second, on my 2000 X, drivers side, my heater is not working. Being a bit backwards, it pulled the seat cover to fix the burnt wires only to discover that there weren't any. I checked the blue/pink wires at the switch and found continuity. **Darn, shoulda done that first.** Then I swapped the under seat module with the passenger seat, and after the swap the passenger seat still works.
I originally thought my switch was fine because the led still works, but the switch "could" still be bad.
Anyone have any other ideas to check?
Thanks,
'Slot
Thanks,
'Slot
Thanks,
